Is it live or is it memorex??? or a real 442
Old February 25th, 2007, 01:59 AM
70vette's Avatar
I am looking to buy a 70 442 conv, partial vin 342670M2401. It has the 442 grill work, hood, and front fender tip trim, and deck lid markings. It has a wing, dual exhaust, and a column shift automatic. VIN says it is a supreme. One web site says there is a W30 and W32 option that put an automatic into a 442. Another web site said that the factory built 442s on the fly once a car was on the line to fill an order.
I know I need the build sheet to know for sure, but, can a 342 code be a true 442???
thx
70vette is offline
Old February 25th, 2007, 05:15 AM
wj67442's Avatar
70 442 Vin Number
From 68 to 71 the first 3 digit's should be 344 to be a TRUE 442 if the digit's on your data plate are 342 your have a Cutlass Supreme that came with a V-8 Hope this helps
WJ
wj67442 is offline
Old November 22nd, 2008, 01:25 PM
FL1970442's Avatar
Your VIN has to say 34467--------- to be a 442 convertible. That being said, the car you are looking at is not worth as much (appraisal wise anyway). In addition, a true 70 442 did not come with "deck lid markings". The only stripes are on the fiberglass hood. The W-30 has side stripes.
You don't need a build sheet to verify a 70 442's authenticity. It only came with a 455, nothing else. Most came with the Hurst dual gate, but you could still order the column if you wanted.
FL1970442 is offline
Old November 23rd, 2008, 09:34 AM
A couple of points. First, be aware that you're responding to a post that's almost two years old. Second, some of your points are not quite correct. The W30 for 1970 did have wide side stripes, but all other 442s came with narrow side stripes. "Most" did not come with the dual gate. The base 442 transmission was the Dearborn heavy duty 3 speed manual with floor shifter. If you ordered the optional automatic, you got the column shifter (whether you had buckets or bench). The Olds floor shifter and console were an extra cost option and the dual gate was an additional cost option on top of that.
joe_padavano is offline
Old November 27th, 2008, 05:54 AM
FL1970442's Avatar
I'm not wrong, 70 442 came with nothing more than hood stripes. You could have dealers add pinstriping or possibly order it, but it did not come with any side stripes.
Old August 29th, 2009, 11:01 AM
FL1970442...you are wrong, and Joe Is correct, and you only got the panel style hood stripes if the W25 ram air hood was ordered, the steel hood had only the optional pin stripes outlining the hood bulges.
1969w3155 is online now
Old August 29th, 2009, 11:22 AM
Trying to remember member
wmachine's Avatar
X2
wmachine is offline
Old August 29th, 2009, 02:13 PM
69'442's Avatar
Did all 70 442's have the deck lid pinstripe also?
69'442 is offline
Old August 29th, 2009, 02:44 PM
wmachine's Avatar
I should clarify this:
The thin side *and* trunk stripes were standard on the 442.
The thin hood stripes were the Y73 "GT" stripes optional on the 442 and the Cutlass S. And the wide (panel) hood stripes were part of the OAI W27 hood option (std on the W30).
wmachine is offline
Old August 30th, 2009, 12:15 PM
Diego's Avatar
So the full hood patches like what was standard on 1969 W-30s was not available in 1970? Never could figure out if the hood pinstripes were standard in 1970 or an option, with no hood patches available.
Diego is offline
Old August 30th, 2009, 12:31 PM
That's correct, 1969 was the only year where dual hood paint panels were available on the steel hood. Standard on the W's and optional on others, with the pinstripe outlining the twin hood raised areas also an option.
Old August 30th, 2009, 12:44 PM
Diego's Avatar
So for 1969, there were two optional stripes? Always had the impression the pinstripes on the hood were standard.
Diego is offline
Old August 30th, 2009, 08:26 PM
FL1970442's Avatar
W machine, the correct hood option is W25 not W27.
W27 is a rear end option.
Old September 1st, 2009, 06:05 PM
wmachine's Avatar
"Hood GT" paint stripes were standard on the 442s and option Y73 on the Cutlass S.
The panel stripes are option W42 "Dual-Stripe" on the 442 (in lieu of the GT stripes) and standard on the W30.
Of course. Mental typo.
wmachine is offline
Old September 1st, 2009, 07:17 PM
vette442's Avatar
...and since the original poster listed it, the 70-72 convertibles did not get the rear decklid spoiler from the factory or as an authorized dealer installed item.
This shot shows the rear decklid stripe as well.
Terry
vette442 is offline
Old September 2nd, 2009, 08:51 AM
Nice piece of literature, Terry. It would be perversely interesting to find out how many wings got installed on 31xx and 35xx cars.
Old September 2nd, 2009, 02:36 PM
Diego's Avatar
Hey, Terry! Peaceful over here, eh? ;-)
Diego is offline
Old September 2nd, 2009, 06:28 PM
wmachine's Avatar
Here's to your perverse interest, Joe!
None of the 31xx and 35xx cars got the factory install, of course.
Here are the numbers:
Approx 1050 on 3200 models
Approx 2720 on 3600 models
Approx 321 on 4400 models
Interesting that means the highest *percentage* of wing installs was on the F85 V8 Club Coupe! About 12.7% of them got the wing.
wmachine is offline
Old September 3rd, 2009, 09:47 AM
344870M's Avatar
I would guess that there are more today than yesterday. Funny how that happens.
344870M is offline
Eddie Hansen
Hurst/Olds
22
April 30th, 2010 04:49 AM
gearheads78
November 26th, 2009 03:41 PM
marinus_
September 7th, 2009 05:39 PM
380 Racer
September 7th, 2009 04:04 PM
oldsdroptop
April 18th, 2009 07:06 PM
Quick Reply: Is it live or is it memorex??? or a real 442
