Pertronix Ignitor II
Old February 23rd, 2010, 07:16 AM
cessna195's Avatar
I have a 1966 442 and I have installed a Pertronix Ignitor II ignition and flame thrower II coil in my car. I have a few questions,
1. I have a Sun Pro 3 3/8" tach and I have it hooked up the same way as if it had a point ignition with the tach hooked up to the neg. side of the coil. Is this OK?
2. How critical is the .010 air gap between the magnet ring and the module?
3. The car has a resistance wire and I have the red wire of the module hooked up to a 12 volt source that comes on when the ignition is turned and I have left the resistance wire and the 12 volt bypass wire that was hooked up the + side of the coil still hooked up to the coil. I think this is correct or is it wrong?
At this time the car will not start.
Sorry for the double post.
Thanks for any assistance.
John
Last edited by cessna195; February 23rd, 2010 at 07:22 AM. Reason: Posted the post two times by mistake.
cessna195 is offline
68442Convertible
September 4th, 2016 04:50 AM
1BAD71455
August 16th, 2013 04:24 PM
amphicar770
October 31st, 2010 05:38 PM
Big Todd
October 16th, 2010 11:38 AM
cessna195
May 15th, 2010 02:35 PM
Quick Reply: Pertronix Ignitor II
