Primary Throttle Shaft Bushing Question
Old March 10th, 2019, 12:07 PM
ben442's Avatar
68 442
Quadrajet feels like something is stuck when I step on the gas at start up. Once I pump the throttle a few times it feels freed up. It will remain free until I let the car sit overnight and then it does the same thing. I've replaced the throttle cable with a new smooth moving part.
Could this be the primary throttle bushings worn out? I haven't had this in any other vehicle before.
This was happening before my winter storage and now that spring is almost upon us I should get it worked out.
Thanks, Ben
ben442 is online now
Old March 10th, 2019, 09:35 PM
shiftbyear's Avatar
Can't say for sure, maybe the accelerator pump? After an overnight sit remove the air cleaner and use a flat blade screwdriver to depress the accelerator pump plunger shaft that sticks up through the hole in the carb. If it depresses smoothly the problem may be throttle shaft or choke related. If the accelerator pump is sticking the carb may need a rebuild. Good luck.
shiftbyear is offline
Old March 11th, 2019, 07:18 AM
oddball's Avatar
You'll probably have to poke around and see what's hanging up.
I've had seals on the accelerator pump cause problems, had a slightly warped secondary shaft, misaligned throttle blades.... all kinds of stuff. Could even be the throttle cable or something with the choke.
The primary shaft problem is that the bores wear out, causing a vacuum leak. Sticking isn't common. So while bushing the primary plate is a good idea, I wouldn't do that first.
oddball is offline
Old March 11th, 2019, 10:18 AM
mrolds69's Avatar
Agreed, you need to investigate it more. My first guess would be the accel pump cup. You can see that carb has been "rebuilt", because there's a plug in the hole where the power valve is. Even though they may have put a modern accel pump in it, some of those don't work well in short order. My second guess would be where the cable hooks up to the carb. In that area, there should be a soft ruber bushing and a hard nylon type bushing inside if it. The inner bushing often wears or falls out sometimes during assembly. Primary shaft problems would be far down my list.
mrolds69 is offline
Old March 11th, 2019, 02:40 PM
Rocketbrian's Avatar
I have the same issue with my 71 quadrajet and determined it to be the accelerator pump. It sticks first time using it after sitting.
Rocketbrian is offline
Old March 17th, 2019, 12:54 PM
ben442's Avatar
Turns out to be a sticking accelerator pump plunger. One drop of oil cleared it right up.
Thanks for the suggestions everyone.
Ben
Old March 17th, 2019, 02:35 PM
mrolds69's Avatar
Problem is, it will be back. You need to change the pump.
mrolds69 is offline
NotDads442
September 7th, 2018 08:34 PM
67Rocket
January 10th, 2017 11:11 AM
pcard
July 19th, 2013 07:09 PM
dick2256
May 28th, 2013 08:25 AM
American Lead
February 15th, 2007 04:58 AM
Quick Reply: Primary Throttle Shaft Bushing Question
