Rochester carburator question..
Old October 19th, 2023, 04:48 PM
  #41
Tancuda's Avatar
A great source to find Delco GM carburetor build sheets is the URL link below. There are many books, pamphlets, etc. - but, I've found this site to be excellent & many are unaware of its usefulness. Click on the "GM" drop-down menu and browse by year. Have fun (sorta). You can d/l any of these .pdf files.
GM Carburetor Build Sheets
Ho, that is a good one ! Thanks
Tancuda is offline
Old October 19th, 2023, 05:02 PM
  #42
That missing port is the ported vacuum source for the distributor vacuum advance on my carburetor (7041250) . It is capped off and I have the line for the advance canister connected to manifold vacuum. I wouldn't send the carb back just for that missing hose nipple - check as much as you can and let the overall assessment guide your choice to send it back or not.
Kenneth - I suspected the same (and considered mentioning it) but wasn't certain regarding the float assembly on that 7043250.
Vintage Chief is online now
Old October 19th, 2023, 05:16 PM
  #43
Tancuda's Avatar
The 7041250 spec are .070 jets, 49B pri rod and AS sec rod
The 7043250 spec are .069 jets, 53C pri rod and CG sec rod
Note: the engine as non stock "J" heads so....
With some research, the 7041250 is closer for 455 eng, same jets and prim rod, sec rod is AS vs AK for original. (could change them if it's that bad).
I don't mind returning it to get the 7041250 for that and the missing port.
What do you think ?
Tancuda is offline
Old October 19th, 2023, 05:24 PM
  #44
You're essentially asking if it's OK to exchange your 7043250 for the 7041250. I'll just note both carburetors were designed for the 350 cid engine. You have a 455 cid engine. I don't have the knowledge to suggest usage of 455 cid jets & rods for either of those 350 cid carburetors. I'd not have a problem suggesting the opposite - using a 455 cid carburetor on a 350 cid engine though - I just don't have the experience. Sorry.
EDIT: And, I suppose, my quandary exists in me not knowing whether the idle circuit is the same which may make a difference.
Old October 19th, 2023, 05:37 PM
  #45
Old October 19th, 2023, 05:39 PM
  #46
Tancuda's Avatar
Ok, thank you for your honesty, if someone can confirm that it's a no-no, I'll just return it, and keep searching for the good one.
Can you believe the current carb on the 455 is from a 1980 Buick rivera V6 and the fuel bowl empties in 24 hours after stopping the engine !!
I can have one from I-5automotive but $$$, the price just rise from 425$ to 592$, I'm in canada so it's a 113$ more for shipping + exchange !!
It's my friend's car, so his decision, but I need to give him some option soon.
I can probably find a used one on ebay and rebuild it.. will see
Thanks again
Tancuda is offline
Old October 19th, 2023, 05:57 PM
  #47
Tancuda's Avatar
Wow that was a good one thanks !
Makes me think the right way I think !
Tancuda is offline
Fazer
December 7th, 2020 05:22 PM
denf221
May 1st, 2018 05:42 PM
Eightbanger
December 21st, 2015 07:24 AM
1arunem
September 13th, 2013 03:36 AM
jonstringer
February 2nd, 2011 07:10 AM
Quick Reply: Rochester carburator question..
