Swapping wheels - will they fit?
Looking to switch to a set of 15 X 7 Olds Rallyes from a 86 442. MY 72 has front discs. I didn't think there would be a clearance problem but after reading another thread, now I'm wondering. Anybody see a problem with this setup? Would love to see some pics of these wheels on an A Body.
Joe, I know that you are pretty knowledgeable when it comes to Olds, so rather than disagreeing with you I will state my experience. Back in 1978 I had a '73 Cutlass Supreme with front disc brakes and the standard full hubcaps. I decided that I wanted the SSII's on this car, so I picked up a set of 14 x 7's from a local junk yard with the bolt on center caps. After painting and installing new tires, I put them on the car, only to find out that the front wheels were rubbing on the calipers, so I had to modify the calipers to fit. It's been a couple of decades, but as I recall, I took a metal rasp to the calipers where it was rubbing to get the clearance I needed.
cutlassefi
November 28th, 2013 12:08 PM
auto_editor
July 10th, 2011 11:20 AM
Aussie67Delta88Custom
Brakes/Hydraulic Systems
October 12th, 2008 12:16 PM
