What size tire are you using???
Old May 5th, 2009, 12:22 PM
ctrain22's Avatar
What size tires are you guys running. I am the new proud owner of a 68 442 and would like to see whattires you are using.
ctrain22 is offline
Old May 5th, 2009, 12:37 PM
Past Administrator
Oldsguy's Avatar
P22570R15s on my 1977 Cutlass, they fit well and look good to me. Plus, they still have enough firewall on them to contribute to the suspension chores as the tires were originally intended to do when new. If you get too much wheel and not enough tire (sidewall) you end up with a harsh ride and hard steering.
Oldsguy is offline
Old May 5th, 2009, 08:49 PM
442much's Avatar
I'm running the same size on my 76 442. 225/70Rx15 is the stock tire size for my car or GR70x15 when it was new.
442much is offline
Old May 5th, 2009, 10:54 PM
is Fast Enough ...
mugzilla's Avatar
I have 225/70/14s' ON 14x7 RALLY ONES ...
I want to get sticky drag tires so I'll have to upgrade to 15x8s' ...
mugzilla is offline
Old May 6th, 2009, 09:33 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
235 60 r15 Indy Firehawks
26" tall
J-(Chicago) is offline
Old May 7th, 2009, 06:07 AM
Wireman134's Avatar
Originally Posted by ctrain22
What size tires are you guys running. I am the new proud owner of a 68 442 and would like to see what tires you are using.
P245/60Rx15 work well if your springs are not worn out in front. Would not run anything wider up front though.
Wireman134 is offline
Old May 7th, 2009, 07:04 AM
car guy
gearheads78's Avatar
what kind of look do you want?
gearheads78 is offline
Old May 7th, 2009, 11:31 AM
4fortwo's Avatar
215-65-15 front
275-60-15 rear
I'm happy with the look and feel.
4fortwo is offline
Old May 7th, 2009, 05:32 PM
oldsdroptop's Avatar
SS1 wheels and tires
I purchased new SS1's wheels from Wheel Vintiques (15 by 8) and B F Goodrich Radial T/A's. 235 60R 15 I like the agressive look of it now. much better for sure. And it throws this 3800 lbs around alot better. Hope this helps. Oldsdroptop
oldsdroptop is offline
Old May 11th, 2009, 08:58 AM
68Tom's Avatar
F70-14!
68Tom is offline
Old May 12th, 2009, 04:41 AM
bittersweet71's Avatar
That's a beautiful car Droptop!
bittersweet71 is offline
Old May 13th, 2009, 12:55 PM
thanx for he compliment
Thanx Bittersweet....appreciate the good feedback.....it was a work in progress for many years to get it this point, and its nice to have some recognition for it.....thanx again.....Oldsdroptop
mmcilroy
September 7th, 2010 05:02 PM
ctrain22
December 15th, 2009 04:38 AM
ctrain22
August 20th, 2009 04:47 AM
Rdrokit
July 5th, 2009 05:11 PM
Quick Reply: What size tire are you using???
