Alero? what are your thoughts
Old November 10th, 2019, 01:05 PM
jensenracing77's Avatar
I am looking for a cheep daily driver and noticed that I can find Alero's for less than $2500 all day long. Does anyone know what the common problems are after 125,000 miles. I know all the normal things at that mileage but wondering if there is anything common like head gaskets or transmissions that go out all the time?
jensenracing77 is offline
Old November 10th, 2019, 02:52 PM
Lansing built
1970cs's Avatar
The 3.4 V6 had issues with intake gaskets. But at that mileage, I would like to think they were replaced with improved metal backed ones by now. Another common problem was the security or passlock issue. There is a bypass, that can be done, just goggle that. Cruise goes out, usually the switch needs to be replaced. Since were in the rust belt, check for rust in the rack and pinion mounting area, engine cradle and rear of the car.
Pat
1970cs is offline
Old November 10th, 2019, 04:49 PM
Pat
I have replaced some of those intake gaskets on the Van models. Not fun on a van. I may go look at one this week but it has the 4 cylinder in it.
Old November 10th, 2019, 05:52 PM
Yellowstatue's Avatar
On a manual trans car, the slave cylinder is inside the bell housing. When it leaks...
Yellowstatue is offline
Old November 10th, 2019, 07:50 PM
I have a co worker with one that he bought from his brother for a winter beater. This is winter #2 with it. Brake lines rusted out, and he is fighting the ignition/security issue right now. It sits idle.
1969w3155 is offline
Old November 11th, 2019, 06:17 PM
Lansing built
1970cs's Avatar
99-01 quad four or 02-04 ecotec?
1970cs is offline
Old November 11th, 2019, 06:21 PM
03 is the one I want to go look at. I also found an 89 calais International series I am thinking about going to look at but it is a little to much money for what I am looking for
Old November 12th, 2019, 06:27 AM
For $2500 you can get an Oldsmobile 88/LSS or Buick LeSabre with less miles and a 3.8l v6. The 3.8l v6 is probably the most durable engine GM ever made. Do a quick YouTube search and you will find plenty of videos that speak highly of them. Check it out!
Olds64 is online now
Old November 16th, 2019, 05:10 PM
Olds Collector
vistacruiser1971's Avatar
Aleros
Olds64: Good idea, they are great cars. Many cars came with the 3.8 V6: 1980's Buick Century, Regals, Olds Cutlass Cieras, Add to your full size list Pontiac Bonnevilles, Olds Silhouettes. Silhouettes are plastic clad which might be a plus in New England or Midwest winters. I had a friend with a 89 Calais Quad four that just ran and ran for ever without problems. I like the Olds Achieva, but would find one with a Quad four and stay away from the 3.1 V6. I also have a buddy with an Alero that he reported one problem, likely the leaking head gasket. Maybe 1977+ RWD 88, Caprice, LeSabre, etc might be found in the right price range. So, it depends if you want a smaller and larger car there are plenty of good choices. You said cheap daily driver, not necessarily a smaller car. Regards, Trent in Los Angeles
vistacruiser1971 is offline
Old November 17th, 2019, 08:02 AM
https://www.youtube.com/watch?v=5lRLmlM8o5Q
One thing about these old Buicks, I agree they are a great car but around here the front cradle rusts out. My son bought a 90( or so) Lesabre that was a nice running low mileage old lady car for his daughter. He asked me to check it out and I could pull pieces of the cradle off with my fingers! It was like the metal gets on a burn barrel- just pulls off like a saltine cracker! My 02 Impala had a aluminium cradle which went 300,000 mile without bad cradle corrosion- though the rest of car was rusty.
Greg Rogers is offline
Old November 17th, 2019, 09:44 AM
Olds Collector
Aleros
Greg: Good point, I saw a nice one posted on the east coast for cheap and the seller said it had rust problems and provided good photos. Nice to see an honest seller. I think the shock support along the bottom looked horrible, like it needed a new cradle. Something to check before purchase on any car, I always look on the bottom. Regards, Trent in Los Angeles
Old November 17th, 2019, 10:39 AM
I found a 1989 98 that I would like to get but he is 3 hours away and about $600 more than I really want to pay. I sent him a message, I will see where it goes.
Old November 17th, 2019, 02:02 PM
Check the cradle on that 98 too. A friend had one of those that was bought new by his since deceased mother and it became so rusty it wasn't safe anymore. He actually junked it and was really bummed because it was such a nice driving car. I don't know how much salt they use in Indiana but here in Michigan salt just destroys our cars.
Old November 17th, 2019, 02:18 PM
Lansing built
1970cs's Avatar
That's why my wife and I trucks, we have a wash package that has the under carriage wash.
Pat
1970cs is offline
Old November 18th, 2019, 05:53 AM
Right you are Greg. This is also the area where sub frame bushings fail. I'm glad I'm not up in the rust belt. Even my 71 98 has barely any rust on the frame and suspension parts and it's getting close to 50 years old!
tgilligan
November 19th, 2018 07:57 PM
FStanley
March 10th, 2016 06:16 PM
Lars
November 30th, 2014 01:51 PM
Bernhard
February 5th, 2013 10:31 AM
Higgins
March 4th, 2011 07:44 AM
Quick Reply: Alero? what are your thoughts
