New ignition and will not start
Old June 23rd, 2008, 04:39 PM
kaboom78's Avatar
Hello All,
I have a 2000 Alero and I just installed a new Ignition Switch w/ Key.
The install went good, but now the car will not start. I'm guessing it has to to with security so it disconnected the negative from the battery for about 5 mins and tried again with no success.
Here is a link to what I installed.
http://cgi.ebay.com/ebaymotors/ws/eB...052489966&rd=1
Any help or idea would be great.
kaboom78 is offline
Old June 24th, 2008, 05:06 AM
Past Administrator
Oldsguy's Avatar
My daily driver is a 1999 LeSabre. Last year it wouldn't start and the dealer changed out the ignition key/cylinder combination. Don't know if there was anyting else to it but the computer may need to be told there was a change made, other wise it is protecting the car thinking someone is trying to hot wire it, maybe? don't know....
Oldsguy is offline
Old June 24th, 2008, 10:09 AM
Just the facts...
BILL DEMMER's Avatar
if the dealer was "paying attention", he would have used a key/lock combo with the same resistance value pellet. you can measure this if you still have one of the old keys.
bill
BILL DEMMER is offline
Old June 24th, 2008, 10:12 AM
Disconnecting the battery on your car won't clear any memory. A 2000 Alero has an OBD 2 computer with Keep Alive Memory. When you replaced the ignition cylinder did you have a Chiltons, or Haynes manual as a reference?
Olds64 is offline
Old June 25th, 2008, 07:09 AM
Does your key have a pellet style Passlock resistor chip or is this the system where there's a magnet in the lock cylinder itself?
joe_padavano is offline
Old June 27th, 2010, 05:12 PM
The Roadmaster's Avatar
I just purchased a 2002 Alero for my daughter. The previous owner put a toggle switch in the system to bypass the security feature.
The security light is on but she runs like a charm.
The Roadmaster is offline
Old June 29th, 2010, 07:09 PM
Barry Jones's Avatar
i just did my neighbors car last year ,what a pain ! if i remember i did a search and found a forum that instructed me to solder a diode near the body control module. the security feature kills the fuel pump ,so leave the key on for 10 minutes and it will start. Hope this helps.
Barry Jones is offline
Old June 29th, 2010, 07:41 PM
extreme1's Avatar
Turn ignition on, wait until security light stops flashing (will go out or come on solid, 10 minutes)
Turn key off.
Turn key on, wait again.....
Turn key off.
When the light shuts off you should be able to start the car at this point. It may not start righ away as passlock II cuts fuel as well as starter in that year.
extreme1 is offline
colemane
April 13th, 2013 01:19 PM
garyfoust
November 25th, 2012 04:32 PM
Destructor
October 22nd, 2010 05:35 PM
rrielley
September 1st, 2008 03:00 AM
justinj
August 26th, 2008 12:59 PM
Quick Reply: New ignition and will not start
