'01 Aurora keyless programming
Old July 28th, 2011, 04:19 PM
DJS70cutlass's Avatar
I've searched on google and found about 3 different ways to do it, none of which work.
Does anyone know how to do it for real??
TIA
Dan
DJS70cutlass is offline
Old July 28th, 2011, 04:42 PM
"Car"mudgeon
GAOldsman's Avatar
I know from experience it is a P.I.T.A. All the steps has to be done within a certain time frame or it won't work.
GAOldsman is offline
Old July 28th, 2011, 04:48 PM
Thats what I figured, but what exactly are the required steps?
Old July 28th, 2011, 05:16 PM
"Car"mudgeon
GAOldsman's Avatar
The one I did was an '03 Poncho and a '01 Tahoe, so I'm not sure if this will work but I found this to try...
Instructions
  1.
    • 1 Enter your Aurora with your ignition key and keyless remote in hand and close all of the car's doors behind you.
    • 2 Insert and remove the key from the ignition.
    • 3 Press and hold the "Unlock" tab on the driver's side door and be prepared to hold it pressed through the following step.
    • 4 Insert and remove the key from the ignition three times in a row and release the "Unlock" tab after the third time. Wait for the vehicle to emit three beeps, indicating the beginning of the programming sequence.
    • 5 Press and hold the "Unlock" and "Lock" buttons on your keyless remote until the system beeps again, indicating that the programming of the remote was successful.
    • 6 Repeat step 5 with any additional remotes, and remove the key from the ignition to end the programming sequence.
Read more: How to Program the Keyless Entry For a 2001 Oldsmobile Aurora | eHow.com http://www.ehow.com/how_6532534_prog...#ixzz1TRrrrCLq
Are you having trouble with your original or what is the purpose of needing to do this?
Old July 29th, 2011, 06:03 AM
The original still works, just trying to add a second remote.
Old July 29th, 2011, 06:39 AM
"Car"mudgeon
GAOldsman's Avatar
Gotcha, I wasn't sure if you were maybe having other probs like the passlock or maybe ignition not reading the chip in the key or something.
Old August 9th, 2011, 02:51 PM
nobody
Old August 9th, 2011, 03:48 PM
I bet if you take it to a Buick dealer, someone there would know how to do it, and probably for free! Seems that in this case the internet is not correct!
oldcutlass is offline
Old August 9th, 2011, 07:09 PM
Boldsmobile's Avatar
Dealer only, unless you have the means to plug into the computer.
Boldsmobile is offline
atikovi
December 10th, 2014 12:00 PM
Takamarak
March 29th, 2013 10:46 AM
kandelino
November 5th, 2010 06:45 AM
robertn
April 5th, 2010 07:34 PM
Quick Reply: '01 Aurora keyless programming
