2001 Aurora upper brake light
Old September 11th, 2014, 12:56 PM
steady 2's Avatar
Looking for information on how to repair the high brake lights on a 2001 Aurora. They are inside roofline lights. Mine are the tan ones which I only see as expensive if I want to buy them new. Any suggestions out there?
steady 2 is offline
Old September 11th, 2014, 01:15 PM
I moved your post here so your question can get noticed. Welcome to the site, post an intro in the Newbie section when you get a chance.
oldcutlass is online now
Old September 11th, 2014, 02:48 PM
I believe you push the rear pod back towards the window, and then pull down gently at the front end to release plastic trim tabs that hold it up. Then slide it out and access the bulbs from the bottom. Most cars today are like this with the third brake light change.
Allan R is offline
Old September 15th, 2014, 03:51 PM
steady 2's Avatar
Thank you. I will give it a try. The only fix I had seen so far was to replace the whole thing and it would cost me at least $400 - was the best price I saw out there. Hopefully I can just replace the bulbs.
steady 2 is offline
Old March 1st, 2015, 04:09 AM
Buck91's Avatar
When my '01 Aurora CHMSL went out I found that the diode on the PCB went bad. Replaced it with a diode from radioshack. Couldn't find the exact right one so I oversized it. Brightness is slightly less than original but OK and much better than not lighting up at all.
Buck91 is offline
Old March 2nd, 2015, 12:21 AM
Yellowstatue's Avatar
Don't forget to shop at your local wreckers...Our Bravada light was out and I picked one up at the wreckers from a Trail Blazer, $15.00. Of course you would have to get an Aurora light.
Yellowstatue is offline
jelardo
Aurora
September 6th, 2011 10:08 AM
easytobedead
November 2nd, 2009 06:03 AM
mikeb
September 14th, 2008 07:28 AM
ajochum
November 30th, 2007 02:40 AM
gregghunter
Aurora
July 21st, 2007 02:13 PM
Quick Reply: 2001 Aurora upper brake light
