96 Aurora rear conversion kit??
Old December 16th, 2010, 07:11 PM
Olds92's Avatar
Hello, the rear of the 96 Olds Aurora has the air shocks/struts. Is there a conversion kit out there?
Olds92 is offline
Old December 16th, 2010, 08:16 PM
Boldsmobile's Avatar
What are you trying to convert it to?
No struts in the back. Its plain ole air shocks. Should be $80 per pair.
Boldsmobile is offline
Old December 17th, 2010, 03:10 AM
Yellowstatue's Avatar
X2 on the 'no struts'. Be sure to get the air shocks with the correct fittings so you won't have to mess around with adapters...
Yellowstatue is offline
Old December 17th, 2010, 05:33 AM
I have purchased Monroes (not generic but for the application) for both my 96 and my 01 and both fit exactly.
Old December 17th, 2010, 08:30 AM
Olds92's Avatar
Is there anyway you can use just a normal gas shock? No air shock?
Olds92 is offline
Old December 17th, 2010, 09:19 AM
You probably could find something to fit but I am curious why would you want to do that.
They arent expensive @ $80 per pair and the auto ride height adjustment is nice when you have passengers in the back seat.
Old December 17th, 2010, 12:56 PM
Past Administrator
Oldsguy's Avatar
So I presume that instead of being routed to a Schroeder valve in the bumper or someplace similar the hoses go to an on-board pump of some kind? I think my '99 Buick Le Sabre has a system similar to that. Auto leveling.
Oldsguy is offline
Old December 17th, 2010, 01:01 PM
"me somebody" site member
aliensatemybuick's Avatar
As these cars with load leveling suspension get older, I can see where any number of failures (to the ride hieight sensor, air compressor system, hoses, etc.) could become expensive to fix or difficult to even diagnose. That's why people have been known to try and avoid all that and go with standard shocks. I loked into this on a 1987 Park Avenue T-type I owned where the system failed; the ride height sensor alone was pretty expensive, nearly 200 bucks as I recall.
aliensatemybuick is offline
Old December 17th, 2010, 02:02 PM
exactly
Old December 18th, 2010, 09:18 AM
Olds92's Avatar
I work at a parts store and a good customer of mine asked about it and I told him I'd look into it. We dont offer a conversion kit and I looked in the Monroe catalog and didn't find one. Couldn't you just find a shock of the same length and same bolt down and use that??
Olds92 is offline
Old December 18th, 2010, 09:48 AM
If you work at a parts store can you pull the correct Monroes out of the box and starting checking other shocks? I am curious as to why you called them struts.
If you remove the air shocks the pump is likely to always want to fill the shocks if the height sensor sees it as too low.
Old December 18th, 2010, 06:59 PM
If you delete the air shocks, simply unplug the compressor...people in the back seat? I thought it was when you had a BB Olds in the trunk for traction...
DeucePhaeton
July 21st, 2014 06:22 PM
therobski
August 5th, 2012 03:28 PM
HIGHCOMP425
December 20th, 2011 07:19 PM
RDSHARE
September 17th, 2010 12:30 PM
strumagic
March 1st, 2004 10:08 AM
Quick Reply: 96 Aurora rear conversion kit??
