Drivers door panel....
Old June 16th, 2010, 07:38 PM
Dave in MN's Avatar
Anyone know how to remove the drivers door panel in a 97 Aurora? I have to replace the outside door handle.
If you could tell me where to start or what the steps are to remove the door panel, I'd greatly appreciate it.
Thanks.
Dave in MN is offline
Old June 17th, 2010, 03:10 AM
Yellowstatue's Avatar
There is a small round plastic cover behind the inside door handle...remove that carefully with a small pick or screwdriver and then remove the philips screw in there and then the big oval plastic piece slips off the door handle...I think there are three or four screws along the bottom edge to remove and the the panel should lift up and then tilt inward...there are two big plastic hooks that the panel will rest upon without removing the panel from the door or disconnecting any wiring...try that... the rod link clip is a little awkward to unfasten...
Yellowstatue is offline
Old June 17th, 2010, 03:21 PM
Dave in MN's Avatar
Thank you! Will keep ya posted as to how it went..........once I get the chance to do it.
matchek
March 16th, 2015 04:20 AM
tysons
April 11th, 2014 04:25 PM
onofre442
December 1st, 2013 10:36 AM
tysons
July 30th, 2013 07:38 PM
2blu442
August 3rd, 2012 01:09 PM
Quick Reply: Drivers door panel....
