mass air flow sensor
Old December 6th, 2008, 06:16 PM
schapman33
Guest
Posts: n/a
mass air flow sensor problem
have 01 aurora. the check engine lt came on , went to the dealer who said mass air flow sensor was bad. the mechanic cleaned it , said it might work and reset the light. Check engine light is back on. can i put an after market sensor on and how would i reset the check engine light.
Old December 8th, 2008, 05:23 AM
Past Administrator
Oldsguy's Avatar
Can't you get an OEM type replacement sensor at the auto parts store? Anyway, if redog doesn't see this post give him a shout via PM, he has some experience with the newer models, so does Olds64.
Oldsguy is offline
Old December 8th, 2008, 06:04 AM
Go to the auto parts store and have them pull your codes. They will do a print out giving you the codes and what they mean. Use that to trouble shoot your problem. If it is the mass air flow sensor then you will probably have to get an OEM replacement from the dealership or the auto parts store. Be prepared to spend some $$$. Mass air flow sensors are pretty complicated devices.
Olds64 is offline
Old December 8th, 2008, 07:49 AM
MAF is $80 for a reman or $165 for brand new from Partsamerica.com. Since your car is OBD II, the only way to reset the light is to use a scan tool.
joe_padavano is offline
Lee_A
August 15th, 2013 12:32 PM
chip-powell
July 7th, 2013 01:31 PM
AZ442
July 16th, 2010 05:34 AM
redvettemike
December 11th, 2009 07:06 PM
cormike
Aurora
January 4th, 2009 07:30 AM
Quick Reply: mass air flow sensor
