1961 Starfire Engine Oil Pan Drain Plug
Old January 23rd, 2024, 12:38 PM
JasonNgreenberf's Avatar
Any ideas on what will replace the oem, and/or where to get one?
JasonNgreenberf is offline
Old January 23rd, 2024, 06:22 PM
Oldsdruid
rocketraider's Avatar
Is yours trashed, or you just can't figure out how to get it out?
If trashed one can come from any 61-64 394 engine and I think a 1965 425. Might be hard to find a hex head drain plug big enough. Someone might know of one.
Use a 1/2" drive ratchet or breaker bar to remove and install it. There's a special 8-point bit for them but the ratchet will do fine.
rocketraider is online now
Old January 23rd, 2024, 06:30 PM
Apparently not in great condition. I was told it was 1/2 inch, but then someone said no. I did find a car part supplier that has one that will allegedly will fit. Hopefully it does and the mechanic working on it has no issues. Thanks.
Old January 23rd, 2024, 08:29 PM
v8al's Avatar
Here's one from a 1965 425. I think it's 7/8" but looks like more than 14 threads per inch. I am guessing it's 7/8-24 or possibly 7/8-20
The official tool to remove is a Bonney A650 but can be removed as described above.
v8al is online now
Old January 23rd, 2024, 09:24 PM
Oldsdruid
The Bonney 8-point tool:
I've fooled with these cars for 40+ years and until I finally found the bit a 1/2" ratchet always worked fine.
Old April 23rd, 2024, 07:35 PM
pagerart's Avatar
Drain plug
Just had the oil changed on my 64 Starfire. They tried the 1/2 inch drive but felt it was going to strip the plug. They finally found a tool that worked but not that Bonney A650. Is there really not a normal plug with the right threads to just replace it. Many show up on parts store websites as 1/2 20. Are those not compatible? I'd buy the tool if I could just find one.
pagerart is offline
Old April 23rd, 2024, 08:34 PM
Oldsdruid
Using the ratchet WITHOUT extensions works better on these drain plugs. Extensions sometimes have rounded corners on the bit end and those will slip in the drain plug and round off the recess.
The 8-point Bonney tool is usually not hard to find.
2blu442
August 11th, 2023 06:52 AM
outrightolds
June 14th, 2022 02:38 AM
zekecut70
October 25th, 2021 05:42 AM
58Oldsw
August 23rd, 2012 05:27 AM
tpawlik
May 8th, 2011 08:19 PM
Quick Reply: 1961 Starfire Engine Oil Pan Drain Plug
