1978 98 regency diesel engine problems
Its a target master diesel, not sure of anything else but that. I was looking through the records the previous owner gave me and could not locate the engine type. I must ask him personally.
Moving on
If I accelerate to highway speed then let off the accelerator, the engine will sometimes deviate from its normal "chug chug chug chug chug burp burp burp burp chug chug chug chug chug burp burp burp burp chug chug chug chug chug" etc which is what I have heard from the car since I bought it. not sure if the burps are normal, but I know the following sequence is not right: "chug chug chug chug chug buuuuurp....... buuuuuuurp......... buuuuuurp........ *shudder and die*" the normal burps cause the vehicle to jerk noticeably probably due to the engine itself jerking around. (it has 23:1 compression after all). Main point being the engine dies after intense acceleration if I haven't warmed it up. It will also die trying to get up hills.
Even if it doesn't die and I am traveling on a highway, it still takes 20 seconds to get to 60 miles per hour. It has good acceleration to start out, but it noticeably slows around 35 miles per hour if the car is not warmed up right until the needle is crawling. The pedal is on the floor and I can't make it accelerate faster. it is not the throttle at all, because after an hour on the highway acceleration is excellent.I think the fuel filter has clogs that get saturated on long drives allowing better fuel flow for better acceleration later in the trip.
My thoughts are this:
the fuel filter needs replacing (likely anyways even if it is not the cause of the problem)
fuel pump
Injector pumps/tubes need to be cleaned/replaced
Any thoughts on this problem and how to troubleshoot are greatly appreciated
Radiator problems:
Happened only once, the radiator fluid overflowed. Since then I have noticed the coolant visibly boiling after only a short trip.
I suspect the thermostat or the radiator itself. The fan seems to be working fine.
Kinked line to the water/diesel separator thingy (Very technical I know... I will upload a photo) needs to be fixed. I know the basics of undoing the clamp and fixing it but not enough where I am confident to actually do it, as I am very noobish when it comes to tinkering around with cars.
Tutorials and troubleshooting for this and all problems stated above greatly appreciated.
Moving on
fuel pump
Radiator problems:
hahahahahahahahahaha and lose the car's character? Diesels are amazing anyways... much more fuel effecient than a gas and can pull heavier loads than gasoline (not that i'd ever use this baby as a work horse) I am going to buy a 1960 something toronado gas from the same guy.... that'll be my gas oldsmobile.
but any help on how to fix the car AS IS with none of this Rodolph Diesel dissing would be much appreciated.
I'd join a diesel forum for the motor stuff, and come hang out here for all the non diesel related items. 99% of the folks on here are gasoline powered.
A few are even diesel blocks converted to gasoline.
Welcome to the forum. No offense, but I can tell you're young.
A Diesel project, and a Toronado project?!!? I think you're insane, and have a lot of work ahead of you.
It will definitely build some character if you pull it all off.
I know better now that I'm older now though haha.
my dad had several of these diesels. i would first change the fuel filters and see what you have. also the antifreeze boiling after a short time has me concerned. it is common to blow head gaskets if you are heavy footed. most likely you have a head gasket problem if it is boiling in a short time. also today's fuel is very dry. you should add a little ATF to your fuel to keep the injection pump in good order.
Thanks for the input. But I have no idea where I could find a diesel group. Nothing is turning up anywhere. But any help you guy can give me is much appreciated. Like I said, very noobish on even basic car functions
Hm. Not the most informative on my type of engine but I do have a 350 diesel I could get free from the previous owner. Thanks! This would be a grat time for me to start tinkering around with engines
It is cool that you have a diesel Olds. You might be the one laughing at us when we all have to park our Oldsmobiles in 15 years when gasoline hits $9.00+ a gallon. I've often considered purchasing a diesel Olds and restoring it. It would even be fun to convert the diesel engine to run on veggie oil.
From what you are describing I would definitely change the fuel filter and do some maintenance on the injectors and lines. From my understanding the Olds diesel engine was pretty durable, it was just the red headed step child Oldsmobile made.
Thanks for the input. Thats what I've been thinking. But the original 350 diesels that this thing would have carried was good in thought, but when manufactured had weak parts. I would have to replace the bolts on the head gaskets and do a bunch of other engine dohickymabobers that I have no idea how to do in order to fix what the inept folks at GM did to it originally.
My engine is a GM replacement engine... a Target master. Pretty much all I know on it right there... cept that it runs pretty good.
KRICHEN922
Paint
February 13th, 2010 09:22 PM
KRICHEN922
November 3rd, 2009 03:08 PM
