324/371 identification
Old August 11th, 2004, 04:12 PM
<rainh8r>
Guest
Posts: n/a
Post
Does anyone know how I can positivly identify my old Olds engine? This was an old blower motor that I have taken apart, with a 4" bore and about a 3.625 stroke (close to a stock 371). The pistons are nearly flat, with only a slight dome. I haven't taken the bottom end apart yet, but now I'm not sure if it's a 324 bored to 4" or a stock bore 371. Does anyone have casting numbers for the block and heads for these engines? I'd like to verify what I've got before going farther. It's also running an Engle 116 cam, which I need specs on if anyone knows. Thanks, Rob
Old August 11th, 2004, 06:45 PM
jdorour's Avatar
Post
The 324 was built from 1954 to 1956:
Engine block Casting Number 568922
The 371 was built from 1957 to 1960:
Engine Casting Number 573562
One sure way to tell, if you have the engine down, is to measure the Main Bearing DIA.
324: 2.498 - 2.499 (#1-4) 2.623 - 2.625 (#5)
371: 2.748 - 2.750 (57 & 58) 2.999 - 3.00 (59 & 60)
jdorour is offline
1956olds
June 21st, 2022 05:33 PM
TOOhep
June 21st, 2013 09:28 AM
d2_willys
September 18th, 2009 08:19 AM
TOOhep
March 28th, 2009 11:33 AM
flatoz
March 15th, 2009 02:03 PM
Quick Reply: 324/371 identification
