425 olds engine code 389244D
Old February 19th, 2007, 11:10 AM
mwmjr's Avatar
Can anyone point me to some information I can find about the 425 engine. The code is 389244D and the year as far as I can tell should be 1966 or 1967.
Thanks for any help
Mike
mwmjr is offline
Old February 19th, 2007, 06:18 PM
2blu442's Avatar
Hello Mike
Check the head casting, if it's a 1965 it'd be "A", 66 a "B", 67 a "C" That would be a letter that's maybe an inch tall located next to the #1 and #8 sparkplug holes. Check the FAQ list at the home page of this site for more details. Also, if it's a Toronado the center of the intake will be sunken and the oil pan will have a provision for the front drive axle, then a little lower in the front and the lowest part of the back will have one side lower. Should have a forged steel crank, and if a 4 bbl carb a higher compression and hp output. John
2blu442 is online now
Old February 20th, 2007, 05:59 PM
70Wcars's Avatar
That is a 66 or 67 425...problem is that motor was available in two configurations. 45 degree lifter angle or the more common 39 degree. Also two lifter Dia. The .921 is the more pricey of the two sizes. There is a " drill spot " on the raised casting on top of the timing case next to the oil filler tube. Can you post a pic of the top showing the casting number and the area next to the oil filler?
70Wcars is offline
Old February 21st, 2007, 09:32 AM
mwmjr's Avatar
I dont have a picture of the spot you are referencing but I will look for the drill hole.
mwmjr is offline
Old February 27th, 2007, 11:30 AM
Freedom Fighter
frdmftr's Avatar
I posted some pics of my 67 425 motor on another thread : look under Eighty Eight section: Help, what is this? Check Images- Need Info
Is there an indicator of which cam angle this is?
FRDMFTR
frdmftr is offline
Boldsmobile
November 2nd, 2011 06:02 PM
ZASX
January 30th, 2010 05:41 AM
rrielley
February 9th, 2008 10:43 AM
psmopar
May 7th, 2007 06:55 PM
Quick Reply: 425 olds engine code 389244D
