Is this a 450 hp 455?
Old March 27th, 2014, 06:53 AM
QS442's Avatar
Looking to purchase a cutlass with a rebuilt 455. I have some of the specs and work done to engine. Seller states it's a 450 HP engine. Would appreciate any input. Trying to see if these specs equal what is being stated.
74-455 with TRW aluminum forged pistons .030" over
Rods were balanced and polished
C-heads- stainless steel valves 2.072" intake and 1.71" Ex. Decked .030, crossover passage filled, hardened seats, new guides.
Lunati street/strip cam with .517/.541 lift & 231/239 duration
Edelbrock Torker II intake
Hooker Headers and flowmaster duals 2.25"
Holley 750 carb vac-sec. w/ electric choke
QS442 is offline
Old March 27th, 2014, 07:14 AM
oldsmobiledave's Avatar
No
Depends.....how much nitrous is he spraying?
To answer your question. No. It is not.
oldsmobiledave is offline
Old March 27th, 2014, 07:40 AM
QS442's Avatar
What would be your guestimate HP?
QS442 is offline
Old March 27th, 2014, 07:41 AM
cutlassefi's Avatar
Originally Posted by QS442
Looking to purchase a cutlass with a rebuilt 455. I have some of the specs and work done to engine. Seller states it's a 450 HP engine. Would appreciate any input. I know the 1974 455s weren't high HP engines. Trying to see if these mods helped that much.
74-455 with TRW forged pistons .030" over
C" casting heads- stainless steel valves 2.072" intake and 1.71" Ex. Decked .030
Carb? Intake? Headers?
cutlassefi is offline
Old March 27th, 2014, 08:15 AM
chadman's Avatar
I say 400ish
chadman is offline
Old March 27th, 2014, 09:02 AM
QS442's Avatar
QS442 is offline
Old March 27th, 2014, 09:24 AM
cutlassefi's Avatar
Originally Posted by chadman
I say 400ish
X2, especially if you don't know what intake and headers are on it. It's not 450 one way or another.
Old March 27th, 2014, 09:35 AM
QS442's Avatar
Headers and intake are now in description
QS442 is offline
Old March 27th, 2014, 09:56 AM
67 Cutlass Freak's Avatar
Ask the seller to see the dyno sheet that proves this engine puts out 450 HP. It's really not that hard to achieve with a 455, but unless the owner actually ran this engine on a dyno, it's purely speculation. The cam used looks pretty tame. Was there any port work done on the heads? Was the rotating assembly balanced? Is there any transferable warranty on the engine work? Will he provide all receipts for parts and machine work? Did the builder provide a blueprint data sheet? These are just some of the questions that I would require answers to, before I pulled the trigger. IMHO the limiting factors on this engine would be the stock rods and heavy TRW pistons.
67 Cutlass Freak is offline
Old March 27th, 2014, 10:20 AM
QS442's Avatar
No dyno sheet. Computer dyno software. Rotating assembly was balanced.
Heads:
Wedge/ Pocket porting/ unschroud valves/ raise port roof/ and polish iron "C" casting heads w/ exhaust crossover passage filled in.
Has machine work receipts. Engine was built by seller, no transfrable warranty
QS442 is offline
Old March 27th, 2014, 10:59 AM
morgan
pogo69's Avatar
i'm no expert but i would say over 400
pogo69 is offline
Old March 27th, 2014, 11:25 AM
cutlassefi's Avatar
Huh Dave?
He asked about the hp, not how high he can spin it. Not sure what "limiting factor" of the weight of the pistons and style of the rods would have to do with the hp output. Guess I don't understand your statement.
I did a .040 over Ga headed 455 last year. The results are on here;
2.07/1.68 valves
10.0:1
RPM intake
850 Proform
Roller cam, 231/234@.050
Flowtech 1 3/4 headers
413hp/496tq.
Yours might make the same, don't think it will make any more than that.
Like Chadman said, 400ish.
71cutlass350
February 2nd, 2013 08:37 PM
Beob
April 17th, 2011 12:37 PM
OldSkoolFool
May 18th, 2010 06:27 PM
stevengerard
December 31st, 2009 04:01 AM
Toro68
August 26th, 2008 06:37 PM
Quick Reply: Is this a 450 hp 455?
