455 exhauset header interference problem help needed
Old January 1st, 2009, 02:07 PM
68conv455's Avatar
I've got a 68 cutlass convertible with a 455. I purchased thorley headers for the cutlass and 455 and just discovered that the passenger side header contacts the fire wall. The header tube just barely touches it. What should I do. I purchased the headers almost 1 year ago so I'm assuming returning them is not viable. The headers also have a nice nickel coating which would be a shame to damage with heat. Should I e-bay them and start over? Help.
68conv455 is offline
Old January 1st, 2009, 02:45 PM
64Rocket's Avatar
Does it touch the firewall or the heater box?
I would make adjustments in the firewall or the box whichever is necessary. Also put some insulating rap around the pipe in that spot.
Gene
64Rocket is offline
Old January 1st, 2009, 02:48 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
That doesn't look too bad. You were fortunate if that is the only problem you had with the fit. My passenger header hit the firewall as well. I just beat the snot of it though. You could always notch out the firewall and weld in a cup.
J-(Chicago) is offline
Old January 1st, 2009, 03:25 PM
same but different
don71's Avatar
If it were me, I would try to clearance the firewall. Probably use a long pry bar against the wall with the header as the fulcrum. Use a rag or something to keep from scratching anything thing.
Worst case, remove header, and clearance the firewall with a hammer.
don71 is offline
Old January 1st, 2009, 04:27 PM
I vaguely remember a similar problem with a set of Thorley headers on my 68 442 that I built in high school (in the last century...).
joe_padavano is online now
Old January 1st, 2009, 05:32 PM
Junior Member
88 coupe's Avatar
Was it a convertible?
Norm
88 coupe is offline
Old January 1st, 2009, 07:05 PM
gearhead1218's Avatar
This calls for a very precise adjustment with a BFH.
gearhead1218 is offline
Old January 1st, 2009, 07:55 PM
Norm
Holiday Coupe. I suspect the problem is production tolerance stackup.
Old January 2nd, 2009, 08:43 AM
citcapp's Avatar
Remove header. Use a 9 pound adjustment tool and create a indent in the area required.
citcapp is offline
Old January 2nd, 2009, 09:16 AM
Past Administrator
Oldsguy's Avatar
I agree with all the recommendations as any/all of them will work. I pose one question though. Is is possibly caused by worn engine mounts? If so, obviously, that might be a fix. I realize that if the mounts were to wear then more than likely the engine would sit a little lower, not back, but just sharing that idea...
Oldsguy is offline
Old January 2nd, 2009, 09:59 AM
1964f-85's Avatar
header fit
I put headers on my 455, 64 cutlass and had the oposite problem, the headers were hitting the passenger side crossmember, what I found out is that the aftermarket engine mounts are sloppy, with factory exhaust manifolds this doesn't pose a problem. I fixed it by welding the holes on the mounts where they bolt to the block closed and redrilling them to raise the engine up, you may be able to do the same, in the opposite direction to lower the engine away from the floorboards. as long as the oil pan doesnt hit the rossmember you should be fine.
Scott
1964f-85 is offline
Old January 2nd, 2009, 08:17 PM
68conv455's Avatar
Norm asked if it was a convertible. It is.
Is there a difference at the firewall on the convertible?
I think I'll try to make some fine adjustments to the firewall, and, fine adjustments to the header tube.
Thanks for the advice.
Old January 2nd, 2009, 10:01 PM
Junior Member
88 coupe's Avatar
Originally Posted by 68conv455
Norm asked if it was a convertible ........
It was that, or ask him if it was a Supreme. Explanation is below.
........ Is there a difference at the firewall on the convertible? ........
Header catalogs say there is a difference (in convertibles and Supremes) but no one knows where, or what, it might be.
Header fitment (or misfitment?) can occur with one of two identical cars. Joe_p's "tolerance stack" theory, makes perfect sense to me, especially if space is limited.
Norm
88 coupe is offline
Old January 3rd, 2009, 12:32 AM
red rocket's Avatar
Remember that your big block will move under power but the firewall/heater will not. I had to do some banging with my 67 CS convertible 455 but no problems now.
red rocket is offline
Old January 3rd, 2009, 05:26 AM
True, however unless you're drag racing in reverse, the passenger side rotates down.
Old January 3rd, 2009, 05:38 AM
Not to high jack this thread, but is this rotation what can cause cracks in the drivers side pillar. I have a friend who bought a real 69 W-30 that came with slicks. [and was drag raced] It has a small crack in drivers side pillar.
Jamesbo is offline
Old January 3rd, 2009, 07:11 AM
But you did...
Yes. Repeated shocks from launching the car causes the body to torque, resulting in fatigue cracks.
Old January 3rd, 2009, 07:34 AM
68conv455's Avatar
Drag race in reverse?
I think you just invented a way to race imports and make it a fair race.
Old January 3rd, 2009, 07:40 AM
But you did...
My sincerst appologies
In the future, I will endeavor to control my inquisitivness.
But thanks for the prompt and accurate [as always] answer
Jamesbo is offline
AZ455
September 22nd, 2022 06:56 PM
rootney
January 1st, 2014 07:22 PM
Olds Dad
August 15th, 2012 11:38 PM
Doc350s
March 26th, 2012 09:58 AM
fmbjogger
October 27th, 2011 07:10 AM
Quick Reply: 455 exhauset header interference problem help needed
