455 Header and alternator bracket problems
Location: Ft Campbell Ky(soon to be Afghanistan again )
Ok here is the issue i have a 455 in my 76 cutlass with headers. I trimmed the lower Alt bracket to fit the headers, but i cannot get the bolt to line up with the mounting hole. I tried just installing the bolt without the bracket still wont line up. Would elongating the hole effect header gasket seal ??
EDIT: Well, maybe the late 70s SBOs used that bracket also. I'm not completely sure. In any case, that's only the bottom of the alternator. There is still the stamped steel upper part that does bolt to the PS pump bracket and the manifold bolt.
Would that work for him Joe? Would that provide a bracket that would bypass the fastener point at the exhaust manifold? Then I guess another consideration would be pully alignment. Would the alternator pully be in a different location than the stamped steel brackets? John
OK.... I replied too soon! I know I have a large aluminum bracket that came off a 1978 Toro with a 403. Then I've got a different big aluminum bracket that came off a 455 that had been installed in a 1978 Cutlass so I don't know what that bracket came off of. I didn't remember them having a lower bracket still... so much for my memory!
More importantly, if you can't get the current bracket to fit, this one won't either. Figure out the problem before throwing money at it. There is no reason why the stock bracket shouldn't bolt up. Photos would still help.
here are the pics
I think i figure out the problem, the lower bracket was bent slightly. Nothing a quick dig through my pile-o-parts couldn't solve
Well, here's a picture of the 307 brackets on a 455. Note the finger pointing to the bottom stamped steel bracket, which still bolts to the exhaust manifold bolt. The aluminum bracket is only the pivot point for the alternator. There still needs to be another bracket that locks the belt tensioning adjustment. There's also no reason why the stock brackets won't bolt up with headers, so let's all wait for photos.
Joe, Very clean engine/compartment, just from the small area shown. ANYONE would like to keep their's looking like that. Really nice!
I dont run the bar that goes to the back of the alternator to the top bracket......i do have my hole elongated some in the bottom bracket just to make it easier to get stuff back toghter......
Never had a problem throwing belts or anything also.........
442mark
September 30th, 2017 01:06 PM
xerxes600rr
August 30th, 2011 06:43 AM
