455 replacement for 425 ?
The crankshaft flange bolt pattern is different on the 64-67 motors from the 68-90 motors. You will need a 1968-up RWD flexplate (350, long stroke 400, 455, 307, they are all the same). The 425 flexplate will not bolt up. Otherwise, the two motors are externally identical.
Ok,thanks.The reason i ask is that my engine had some crankcase ventilation
so i suppose the pistonrings are leaking compression,have removed the pcv valve in the left valvecover and replaced it with a vent tube.
Have also made an oilfillertube cap with 3/4" vent outlet i hope to minimize the crankcase vent to the aircleaner from the right valve cover.
Have an oil leak somewhere behind left cylinder head i must look at,a lot of oil needs to be filled in the engine.Oilpressure are 25-30 psi when driving with engine hot,guess this are ok.My Chevy truck have 30 psi warm also.
But the 425 runs smooth and steady at idle so i should try to fix the oil leak
for now.
Yes Lansing,i like the 425 also.it must been a awesome feeling to drive these cars when they were new from the dealer.
/Glenn.
for now.
/Glenn.
steve walker
December 17th, 2019 12:32 PM
Nickyloves442s
July 7th, 2015 12:19 PM
ForestMist66
October 15th, 2012 03:22 AM
