68 400 timing marks ?
Old September 8th, 2009, 03:16 PM
bullet1's Avatar
wanted to check timing but cant tell where marks are on tab anyone have a diagram of this also my book shows 7.5 timing others show tdc what should it be on my 442?thanks for any help
bullet1 is offline
Old September 8th, 2009, 03:57 PM
MX442's Avatar
Bullet, I'm not home to get you a diagram or picture. The tab has the "v" grooves in it. IIRC, the first one is 0, and the last one is 10. They are cut out on the tab as a circle and 10. You'll get all kinds of different answers on timing. Book is correct if you have stock cam, distributer, and compression. Otherwise, go all in no vacuum at 34, add or subtract 2 degrees until it's happy.
MX442 is offline
Old September 8th, 2009, 05:19 PM
bullet1's Avatar
bumped timing up it was a 0tdc set to about 7.5 definitely helped actually squawk tires a little when you get on her.now i know where im at picked up hei distributor this weekend get new plugs and wires on. get her to run better yet.
thanks
bullet1 is offline
Old September 25th, 2009, 10:47 AM
It's a sickness!
Toyaholic's Avatar
Pictures?
Anybody find pictures of the timing tab? I've got a 1969 455 and can't tell where the numbers are on the tab.
Toyaholic is offline
Old September 25th, 2009, 01:23 PM
svnt442's Avatar
thanks
The HEI is going to change your initial drastically. HEI distributors use a way different advance curve with more initial and less mechanical advance unless it has been modified with an advance curve kit.
When you drop in the HEI it's going to need 20° initial @ 1100 RPM.
svnt442 is offline
Old September 25th, 2009, 03:33 PM
MX442's Avatar
It is hard to see in the pictures. The bottom "V" is zero, the middle is five, and the top "V" is 10.
MX442 is offline
Old September 25th, 2009, 05:44 PM
It's a sickness!
Toyaholic's Avatar
Thumbs up
Thanks MX, just what I needed.
Carshinebob
September 11th, 2013 04:06 AM
willj
May 18th, 2010 02:09 PM
iam2fast4u86
February 4th, 2009 06:31 AM
cisco88
October 17th, 2008 07:12 PM
MIRADAMANia
April 22nd, 2008 01:00 AM
Quick Reply: 68 400 timing marks ?
