68/69 model 455-out of what car?
I would imagine if you had the numbers off the vin pad on the block someone could check them against the 68 or 69 H/O registry. I'm thinking it would be a long shot though. You might make someone pretty happy if you had their matching numbers engine though
Post the partial VIN number stamped below the driver's side head, behind where the power steering pump would mount.
38M614186 = 3-Olds 8-1968 M-Lansing 6-Toronado 14,186-unit# (late Feb. '68 production)
...maybe
look for a series of numbers(about 3/8" high), stamped on the oil fill tube, towards the top. the first #(i think there is eight altogether), indicates engine build year. it should read 8 or 9 XXXX and so on. may or may not help you if the tubes been replaced. sometimes you have to clean-off the tube and the #'s may be facing towards the intake mainifold.
vertex
March 21st, 2013 02:09 PM
