Aluminum Radiators
Old September 12th, 2009, 06:19 AM
pureplaya442's Avatar
Aluminum Radiators
Im in the process of shopping around for an aluminum radiator, and I want something thats going to keep my Big Block nice an cool. Who's makes a good aluminum radiator out there? Im also thinking of running electrical fans vs. the old mechanical fan. Any suggestions?
pureplaya442 is offline
Old September 12th, 2009, 09:38 AM
nickd's Avatar
I bought a four row from Genesisautoparts.com for $160 shipped. I had to make up some new top brackets but it turned out well.
nickd is offline
Old September 12th, 2009, 10:15 AM
I would check out Summit. They have house brand parts that are reasonably priced and perform just as well as an expensive unit like Griffin or BeCool.
Olds64 is offline
Old September 12th, 2009, 11:48 AM
My442's Avatar
I have a Be Cool.
Dropped my running tempreture from 210 to 180.
It replaced a recored 4 core.
My442 is offline
Old September 13th, 2009, 07:29 AM
Thats about what I want to be running, about that 180 degree range. Now your Be Cool do you have electric fans, or are you still using the mechanical fan?
Old September 13th, 2009, 03:12 PM
My442's Avatar
I run a Be Cool radiator, factory fan shroud, factory clutch fan, and a high flow 180 degree thermostat.
The coolant is 30% green antifreeze, 70% distilled water, and a pint of NoRosion.
My car will run at 180 degrees even if it is 90 degrees out.
My442 is offline
AZ455
August 9th, 2016 11:47 AM
RandyS
June 25th, 2015 02:57 PM
69350rocket
August 8th, 2011 02:52 PM
jo75olds
January 31st, 2011 07:55 PM
mp71conv
August 2nd, 2009 11:18 AM
Quick Reply: Aluminum Radiators
