Anyone try a Tremic 5 speed?
Old February 6th, 2010, 05:01 AM
MN71W30's Avatar
Our 71 had a Muncie 4 speed. We then installed a 5 speed Doug Nash/Richmond and It falls out of 4th gear. I Noticed the Tremics are rated to be strong and reasonably priced. Anyone have an opinion about them?
MN71W30 is offline
Old February 6th, 2010, 06:06 AM
citcapp's Avatar
Richard (gearheads78) Has one in his 67 and he likes it. PM him for more details. I bought one to install in my 48 Olds.
citcapp is offline
Old February 6th, 2010, 07:39 AM
MN71W30's Avatar
Thanks, I'll send a PM.
MN71W30 is offline
Old February 6th, 2010, 07:44 AM
car guy
gearheads78's Avatar
I love mine. Great modern interal rail shift feel and cruise at highway speeds at under 2000 rpm.
gearheads78 is offline
Old February 6th, 2010, 06:07 PM
Past Administrator
Oldsguy's Avatar
Hah! I remembered that you had one in your car Richard and immediately thought to myself, he's gonna reply. Just knew it!
Oldsguy is offline
Old February 6th, 2010, 07:16 PM
507OLDS's Avatar
I know a few that have put the Tremecs in their Cutlasses,& I have a 71 442 here with a Richmond 5-spd. Another thing you might consider is an aftermarket gear cluster for your Muncie. Maserio makes a stock ratio cluster,& an overdrive cluster,keeping the 2:20 1st,but bumping 2nd up closer,& making 3rd 1:1,and making 4th .80. Just a thought.I wanted my W30 to look totally stock,& this helps with 3:91-geared cars.
507OLDS is offline
Old February 6th, 2010, 07:45 PM
car guy
The new Mcleod transmission comming out looks very promising too. If its a good as they say it is and fits with no cutting the TKO tremecs will become obsolete.
Old February 6th, 2010, 10:22 PM
MN71W30's Avatar
I buying a Richmond 5 speed with a shifter to replace my Doug Nash. I won't have to change anything.
Thanks for the help.
MN71W30 is offline
Old February 6th, 2010, 10:38 PM
car guy
You know the Richmond is the Doug Nash right?
Old February 7th, 2010, 06:03 AM
MN71W30's Avatar
Yes,
I got one of each already, you can't tell the difference except for the name on the case.
MN71W30 is offline
Old February 7th, 2010, 09:13 AM
car guy
Yes,
Ok just making sure you didn't think you were getting an overdrive by going Richmond
Old February 9th, 2010, 04:28 AM
507OLDS's Avatar
The shifter placement on the Richmond 5-spd is farther back,compared to a Munice 4-spd.The hump will need modified,& if you have a console,the boot assembly will need to be moved back as well.This is what needed to be done on a 71 442 4-spd convertible.
507OLDS is offline
Old February 9th, 2010, 08:19 AM
1964f-85's Avatar
I just did a high horse power rebuild on a Mustang T-5 for my 64. It required a little fabrication to fit but went in with very little work. My car is mostly a street cruiser and I haven't raced it, so I am hoping for a long and happy life together. I estimate that with a 2:95 1st gear and an over driven 5 gear, with my 3:25 axle to have a very fun street car. FYI the car was raced with a Saginaw 4-speed for 10 years before it spit out the cluster gear, the T-5 should hold up better than the Saginaw did.
1964f-85 is offline
tmaleck
August 15th, 2021 08:17 AM
costpenn
Body work
33
June 28th, 2012 05:51 PM
CutlassLegend
August 15th, 2011 04:34 AM
brokeandugly21
Ninety-Eight
30
April 8th, 2011 03:04 AM
RAMBOW
July 7th, 2010 05:39 AM
Quick Reply: Anyone try a Tremic 5 speed?
