Best method to clean and degrease an engine on an engine stand?
Old December 30th, 2008, 06:29 PM
cts-v's Avatar
I need to clean and degrease a 455 on an engine stand. Are there any tips or tricks to make it easier (other than just dousing the thing in engine degreaser)?
cts-v is offline
Old December 30th, 2008, 06:58 PM
car guy
gearheads78's Avatar
I put mineral spirts in a bug/weed sprayer and spray a little at a time keep the mess to a minumim. Lots and lots of spraping tooth brush cleaning to aggitate the mess.
About 3 solid hours cleaning in the block and heads before this pic
gearheads78 is offline
Old December 30th, 2008, 11:08 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
engine degreaser, and then a pressure washer. Repeat as necessary. A lot more mess than Gearheads78's method, however. Done in under an hour. Not advisable in temperatures below 33 degrees Fahrenheit.
J-(Chicago) is offline
Old December 30th, 2008, 11:19 PM
MDC
MDC's Avatar
Get the cheapest oven cleaner you can find. Spray it down and let sit for an hour or so, then go to it with scrub brushes. Add cleaner as needed and you'll be able to tell when it is all broken loose, then hose it down.
Be sure to put a piece of cardboard under the stand as you spray and scrub and wear rubber gloves.
MDC is offline
Old December 31st, 2008, 04:26 AM
Past Administrator
Oldsguy's Avatar
X2 on oven cleaner. But be careful, it is very caustic and will burn your skin.
Oldsguy is offline
Old December 31st, 2008, 08:39 PM
Registered Luser
ent72olds's Avatar
I personally use a product called GREASED LIGHTENING. I know home depot sells it for about $7 a gallon. Way cheaper than engine degreaser. Put it in a spray bottle, spray it on and let it soak a little spray more, scrub rinse. Have fun! Have a beer!
ent72olds is offline
Old January 1st, 2009, 08:50 AM
citcapp's Avatar
I use a cheap degreaser lay down a large cheap plastic painter's tarp under the engine the clean. After the cleaning is complete I gather up the platic tarp and put it in a plastic garbage bag and of to the dump it goes
citcapp is offline
Old January 1st, 2009, 09:01 AM
65Delta88's Avatar
I just used engine bright when I cleaned my motor, I think I went through about 2 1/2 to 3 cans of that stuff. I just let it soak for about 10 minutes and then I scraped all of the goop off. I thought it worked great and then I just sprayed the motor with a pressure washer when I was done.
65Delta88 is offline
Old January 1st, 2009, 09:03 AM
If you are going to have the engine rebuilt it really isn't necessary to degrease it extensively. I took a short block to my machinist and the only parts I "degreased" were the valve covers, heads, oil pan, intake, and brackets. These were all removed from the engine though. Once the machinist gets it he will hot tank it and that will destroy the grease instantly.
Olds64 is offline
Old January 1st, 2009, 07:37 PM
Redog's Avatar
I used a combo of engine degreaser and disc brake cleaner, and the hose. All in the bed of a rental F-150
Redog is offline
Old January 1st, 2009, 07:56 PM
Eric Anderson's Avatar
I also like to use cheap degreaser, and brake cleaner(cheap as well). First i scrape the heavy crud off then let the degreaser work and hit it with a small brush and a tooth brush, then use the brake cleaner to blast out the tight spots rinse it off and your good to go. Oh and I use a plastic storage box that I stole off the wife to catch the drips.
Eric Anderson is offline
Old January 10th, 2009, 06:11 PM
Purveyor of Polyurethane
ijasond's Avatar
I assume you are prepping it for paint? All of the degreasers listed above, brake cleaner, oven cleaner, paint solvents, lacquer thinner, paint prep solvent cleaner, etc. will do the job. Multiple cleaners is the way to go because different ones work better on different contaminants. Just start with your strongest solvent based cleaner first & finish the job with a water based cleaner & preferably a pressure washer. If you use several cleaners in succession, it can be done fairly quickly & without all the toothbrush scrubbing. If you have just assembled the engine, you shouldn't have major gunk, only a bit of oil, assembly lube & hand prints. One thing is certain, it will never be too clean for painting.
ijasond is offline
Old January 10th, 2009, 06:20 PM
68conv455's Avatar
Whatever you use. Use it in a well ventilated area. Most of it is no good for you.
68conv455 is offline
jaunty75
January 1st, 2019 06:51 PM
DewChugr
Paint
June 9th, 2015 06:40 AM
scrappie
September 16th, 2012 04:07 AM
jslabotsky
December 4th, 2011 06:35 AM
Aceshigh
Brakes/Hydraulic Systems
April 21st, 2010 08:33 AM
Quick Reply: Best method to clean and degrease an engine on an engine stand?
