Cam gear and Timing Chain - Advice needed
Old January 30th, 2013, 10:42 AM
fv64olds98's Avatar
Hello All,
I have an olds 1964 98 with the 394 Sky Rocket engine. I bought a new timing chain and installed it. It thas the exact same number of links as the original. However, the part of the links that goes into the cam gear tooths is not as long so it does not seat all the way into the tooths of the cam gear as the original chain did.
Has anyone changed the timing chain on a 394? I am a bit concerned that this could lead to potentially jumping a tooth or even damaging the plastic tooths on the cam gear?
Any suggestions would help.
I did not buy a new cam gear, as the original looks good, but maybe i should buy a new cam gear with metal tooth.
fv64olds98 is offline
Old January 30th, 2013, 10:56 AM
boese1978's Avatar
"but maybe i should buy a new cam gear with metal tooth."
Always!!
boese1978 is offline
Old January 30th, 2013, 12:33 PM
m371961's Avatar
I never replace a chain without replacing gears. Always replace nylon capped gears with steel. For performance, double row chains and gears.
m371961 is offline
Old January 30th, 2013, 02:51 PM
Run to Rund's Avatar
I chose a Cloyes true roller chain and gears, but that was 40 + years ago; look for something similar today. Ross Racing in Ohio may be able to help if you can't find them at the usual places.
Run to Rund is offline
Old January 31st, 2013, 11:19 AM
fv64olds98's Avatar
Hi All,
Thanks for the advice, have gone ahead and orders a 3 piece set 2 gears and chain. Makes sense to replace all. Should have asked before i ordered just the chain.
Old January 31st, 2013, 01:45 PM
m371961's Avatar
Assuming you are installing new front seal. If you use the balancer sleeve and have never done it before, you may want to ask for suggestions to install it.
m371961 is offline
Old January 31st, 2013, 01:51 PM
fv64olds98's Avatar
Hello m371961,
Sorry I am not sure what do you mean by sleeve? I am planning to replace the front timing cover Crankshaft pulley seal. Could you exaplin what is meant by sleeve and why would i use one? If I do need one, is there any tips or tricks on installing it?
Thanks for all your help
Old January 31st, 2013, 01:59 PM
same but different
don71's Avatar
He might be refering to a "speedy sleeve" commonly used to cover up the groove that timing chain seals often wear into crankshafts. Helps to control oil leaks, very common to use one.
Check out this recent thread...https://classicoldsmobile.com/forums...ve-n-seal.html
don71 is online now
Old January 31st, 2013, 02:56 PM
m371961's Avatar
Good instruction here. http://www.skf.com/binary/12-61918/TT08_021.pdf.
Page 2 shows sleeve on dampner nose. The only thing I do different is that I chill the dampner, put sleeve on a lightbulb to get hot then install.
m371961 is offline
Stevec
February 8th, 2015 01:25 PM
Freddy B
September 3rd, 2014 08:26 AM
jerseyjoe
November 11th, 2011 04:07 PM
henryk8398
March 5th, 2010 09:38 AM
smcurro
February 27th, 2009 09:27 AM
Quick Reply: Cam gear and Timing Chain - Advice needed
