can you get a lifter out without pulling heads?
Old May 8th, 2009, 04:15 PM
Flye's Avatar
67 400
If I go that far, I probably should pull heads and have them redone, but just for my knowledge base.....
Can you pull intake, and pull push rods and get a lifter out, or does the head have to come off?
Just trying to figure out options.
and yes, I realize many will say "just pull heads and do valves if you're that far....".
Thanks,
Flye is offline
Old May 8th, 2009, 05:07 PM
same but different
don71's Avatar
The head doesn't have to come off per say, they can pulled out from the valley.
Beware....there can be a build up of varnish/gum deposits that will make them very stubburn and tough to pull out. If that happens, you have to knock them into the engine. You'll be pulling the oil pan off to get them out, not the heads.
edit...in order to knock the lifters in the engine, the cam has to removed.
don71 is online now
Old May 8th, 2009, 06:40 PM
Bass ackwards is possible but not advisable.
Pull the heads.
Jamesbo is offline
Old May 8th, 2009, 06:55 PM
jensenracing77's Avatar
you don't need to pull the heads. if you have a stuck lifter in the bore you can pull them out with an internal barring puller for small barrings. you will ruin the lifter doing this.
jensenracing77 is offline
Old May 8th, 2009, 07:34 PM
OR...
You could just get the right tool for the job and not ruin anything.
http://www.amazon.com/gp/product/B00...&redirect=true
joe_padavano is offline
Old May 9th, 2009, 04:17 AM
scrappie's Avatar
That looks like the tool to use. I don't understand why the head should come off to get a lifter out? After the intake is removed you can get to the lifter with that tool Joe suggested or not. How would the head being removed give you more access?
scrappie is offline
Old May 9th, 2009, 05:13 AM
OR...
that is the same thing as my little internal barring puller. i just figured it would scuff the lifter.
Old May 9th, 2009, 07:07 PM
It's not the same as a BEARING puller. The lifter puller has small teeth that are designed to fit into the snap ring groove on the lifter so there is no damage. The black cylinder acts like a slide hammer to knock the lifter out. If that doesn't work, the nut on the upper part can be threaded down against the head (the puller rod fits through the pushrod hole) to pull the lifter out.
Old May 10th, 2009, 08:13 AM
Warhead's Avatar
Riddle me this, Batman...
How many miles on this engine, and why do you want to pull them?
Yes you can do this.
If you want to do a cam swap on a high mileage engine, I DO recommend pulling the heads (but you know that already).
Jim
Warhead is offline
MDchanic
31
August 12th, 2012 04:24 AM
getitmann
July 12th, 2012 06:58 PM
ChefDeadpool
37
May 23rd, 2012 08:32 PM
Aceshigh
September 29th, 2010 10:31 PM
krissiibabii
August 18th, 2010 05:35 PM
Quick Reply: can you get a lifter out without pulling heads?
