cylinder heads "J" or "H"
Old November 8th, 2007, 12:47 PM
Member
Swed Olds's Avatar
Question cylinder heads "J" or "H"
Hi there
Is there anyone out there who can help me with cylinder heads of the 1964 394”?
On my car the ID on the cylinder heads starts with an “H”. One of them is cracked so I get another one, there the letter is “J” in the beginning. Is there a big different between them, can use the “J” marked on my engine, can I use the same valves as in the “H” head?
Thanks Per
Swed Olds is offline
Old November 8th, 2007, 01:35 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
J and H heads are for a 455 olds motor.
Also the H head is VERY RARE and valuable. Are you sure it is an H head that you cracked?
I'll definitely take it if you don't want it anymore.
Is this car in Sweden?
an H head is probably worth twice the amount of the car that you have it in.
J-(Chicago) is offline
Old November 8th, 2007, 01:40 PM
and yes if it is a 455, the j heads will swap.
Old November 8th, 2007, 01:45 PM
Junior Member
88 coupe's Avatar
Originally Posted by Swed Olds
........ of the 1964 394”? ........
Norm
88 coupe is offline
Old November 10th, 2007, 02:27 AM
Member
Swed Olds's Avatar
It must be some kind of mistake, i´m talking about a 394" from 60-64 and my head has the ID: "H 069 822L and the other has: J 281 677.
And the reason is that i saw on tha Falcon sales E-store, it was different valves for Starfire and the other ones (i have an Dynamic 88 but what car the "J" head came from I don´t have any idea.
//Per
Old November 18th, 2007, 07:04 AM
I'll be damned.......
Could someone further explain this to me?
Different heads all together?
Old November 18th, 2007, 04:51 PM
I see. Thanks.
I have never even seen a 394 before.
defiant1
August 22nd, 2015 08:13 PM
vanguardtdc
March 30th, 2015 09:32 AM
coldfire
July 19th, 2013 08:20 AM
67442nut
Brakes/Hydraulic Systems
June 16th, 2011 06:14 AM
81 regency
April 21st, 2011 06:18 PM
Quick Reply: cylinder heads "J" or "H"
