Do I need new rings with new pistons? Ball honed cylinders.
Old January 15th, 2009, 05:36 PM
cts-v's Avatar
I've gotten a lot of good help and advice about the '72 455 I'm planning to put in my Cutlass Supreme. Short story... due to budget constraints, I'm not going to do any machining at this point, but I am going to swap in a set of used standard bore high compression pistons graciously donated by another forum member here (thanks Dan B). The engine will be torn apart in about 2 years for a 'real' rebuild (bore, cyl heads, roller rockers...).
If I ball hone the cylinder walls, I presume I'll need new rings? All 3 rings need replaced? If so, is there any particular type of ring you would suggest, or will off the shelf "Autozone" or "NAPA" rings work?
This will be street only car, so I'm not looking for max power (though I guess I am looking for more power if I'm wanting the higher compression pistons).
Thanks. Tom.
Last edited by cts-v; January 15th, 2009 at 05:40 PM. Reason: clarifying that the pistons are 'used'
cts-v is offline
Old January 15th, 2009, 05:55 PM
64Rocket's Avatar
You should at least put new rings and brg's. Check with "Summit' and rings are $20 to no end. Get a set of cast rings and you will be good to go. When you check "Summit" look up the rings by size not by engine.
Also be sure to have the crank polished. Be sure to hot WASH the block, not hot tank.
Gene
64Rocket is offline
Old January 16th, 2009, 04:28 AM
Gene is right on. Definitely put new rings and bearings in it. Make sure the ring gap is set properly.
Olds64 is offline
Old January 16th, 2009, 05:16 PM
cutlassefi's Avatar
New Rings?
Ring gap will probably be wide anyway, based on the fact that the bores are probably worn a bit. Unless you go to file fit (more money), that's a futile effort.
Make sire you wash the bores really well, good enough is not good enough. You'll eat up a set of rings (especially cast) and bearings pretty quickly if you don't.
cutlassefi is online now
Old January 21st, 2009, 12:35 PM
Charlie_brown's Avatar
Gene
why hot wash and not hot tank. What would be the effect if hot tanked
Charlie_brown is offline
Old January 22nd, 2009, 12:44 AM
Junior Member
88 coupe's Avatar
Caustic, used in the hot tank, will eat the cam bearings.
I expect 64Rocket will add more.
Norm
88 coupe is offline
Our88
September 17th, 2014 06:39 PM
csouth
November 21st, 2011 02:31 PM
88hurstolds
April 27th, 2011 12:13 PM
blue72regency
November 10th, 2007 05:02 PM
Quick Reply: Do I need new rings with new pistons? Ball honed cylinders.
