Easy ? RE: Front Seal
Old November 15th, 2006, 11:38 AM
kcompton's Avatar
Hi all, I'm new to Olds Big Blocks, and have a timing cover to balancer seal to replace. Is it necessary to remove the timing cover to do this job, or can I just remove the balancer to get to it?
Thanks,
Ken
kcompton is offline
Old November 15th, 2006, 02:07 PM
Past Administrator
Oldsguy's Avatar
That seal is pressed in, I doubt you will be able to remove it without removing the cover, or install the new one for that matter. That is something the Chevy guys always rib me about (only thing??) the cover isn't two piece like theirs so that job neccesitates the full removal of the cover, and the water pump. But you are already halfway there by the time you get the balancer off anyways so....
Oldsguy is offline
Old November 15th, 2006, 02:26 PM
kcompton's Avatar
Really? That's too bad... I was told that it could be done without removing the cover. I haven't had alot of experience with the bottom ends of engines. So there's no way for me to get that seal out and the new one in without a press?
Thanks.
kcompton is offline
Old November 16th, 2006, 04:42 AM
Past Administrator
Oldsguy's Avatar
Well, you might be able to pry the old one out from the font side and the hammer a new one in. Nothing is impossible, I have just never done it that way. Give it a try and let us know how it turns out.
Oldsguy is offline
Thuffner3
December 11th, 2007 07:38 PM
big-al-D-88
30
December 2nd, 2007 01:09 AM
1BAD68"S"
November 9th, 2006 04:30 AM
RussTad
September 19th, 2006 02:16 PM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: Easy ? RE: Front Seal
