Fuel filter
"Normally" there is a metal line from the fuel pump to the carburetor, and the fuel filter is inside the inlet housing that the metal line attaches to.
On QuadraJets the fuel line attaches to the front of the carb. I can't tell what carb you have, other than it's not a QJet.
Someone has added braided hoses and an inline filter to that engine.
Looks like an Edelbrock carb was put on. They have the rear fuel inlet and I have seen many fuel lines sitting on the heat crossover of the intake. You should re-route that line, or better yet, get a correct Quadrajet!
IF you are concerned about your starter being too close to your headers you can get a thermal blanket to wrap around your starter. Sometimes the starters on Olds motors have heat soak issues but that can usually be cured with a starter in good condition and a good tune.
oldspackrat
March 21st, 2016 05:17 PM
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
DanOldsMan
February 10th, 2014 07:18 AM
joepenoso
July 19th, 2013 12:44 PM
