Gear drive timing.
Old April 17th, 2014, 11:06 PM
Acceleratii maxim rapidus
73aussie455's Avatar
Gear drive timing.
Just curious if anyone has any experiences with gear drive timing as opposed to timing chain?
I found this kit for the Olds 455. I'm not thinking about replacing my timing chain, just putting the question out there. As I recall a gear driven cam makes a sweet, although loud, whirring mechanical noise. I'm guessing there would be no issues with a chain wearing out. Would gear driven suit higher HP builds or higher rev's?
What are the pro's v con's of both setups? Interested in your thoughts, opinions.
73aussie455 is offline
Old April 18th, 2014, 06:17 AM
The timing nor the procedure changes with the gear drive. Yes some do sing a pretty tune. They are pretty accurate and eliminate the issues associated with chain stretch.
oldcutlass is offline
Old April 18th, 2014, 07:37 AM
Proud Viet Nam Veteran
redoldsman's Avatar
They sound like a blower. I think I would get tired of it. I guess it depends on the car.
redoldsman is offline
Old April 18th, 2014, 02:41 PM
Engine Builder
Smitty275's Avatar
If your running massive spring pressures it could make cam timing and ignition timing more consistent. BUT gear drives can also induce unwanted harmonics. I wouldn't waste the time or money on it. I guess it would be neat at the car shows because those guys think a gear drive is just awesome and only used on megga HP builds.
Smitty275 is offline
80_cutlass
September 1st, 2018 05:55 AM
71RadioflyerVista
June 28th, 2011 09:11 AM
442scotty
May 13th, 2009 05:42 PM
65cutty
March 11th, 2009 05:14 PM
salayc
December 3rd, 2008 09:48 AM
Quick Reply: Gear drive timing.
