got the 455 together.nothing but an occasional backfire??
Old July 21st, 2013, 03:03 PM
joepenoso's Avatar
Question got the 455 together.nothing but an occasional backfire??
I got the 455 together...................nothing but an occasional backfire??
I replaced the camshaft, lifters, harmonic balancer, water pump, timing chain. I carefully had#1 cylinder at TDC when replacing the gears and chain.
the distributer had the vacuum canister facing passenger side rear and number 1 cylinder ( Distributer) had the rotor pointing to #1 cylinder.
Any Ideas??
thanks in advance
joepenoso
joepenoso is offline
Old July 21st, 2013, 03:17 PM
Alb
Alb's Avatar
backfire
I had the same problem on my 455. I found that I was brain dead on my timing gear. Got that fixed and made sure that the timing mark was at 4 degrees( about). Made sure I was on compression when I check the position of the rotor. It fired right away. Ran a little rough until I timed it. With yours back firing. I would say it is a timing problem. Double check everything. Hope this helps.
Alb
Alb is offline
Old July 21st, 2013, 03:26 PM
Originally Posted by joepenoso
Any Ideas??
Distributor is 180 deg out.
joe_padavano is online now
Old July 21st, 2013, 04:24 PM
joepenoso's Avatar
Question
Make sure balancer and pointer are at 0 or maybe +4 degrees TDC.
Check it's the compression stroke by having no spark plug and feeling air pressure against the finger as it reaches that position.
Make sure distributor rotor is pointing at #1 cylinder plug wire.
Fire her up and break in the lifters
is that it??
joepenoso
Old July 21st, 2013, 04:31 PM
Grace Stinespring-Welch's Avatar
sounds like timing is off or a stuck valve.
Grace Stinespring-Welch is offline
Old July 21st, 2013, 05:02 PM
Oldsmaniac's Avatar
When timing gears (marks) are lined up at 6 and 12 and #1 is at TDC it is not on compression stroke. It is 180 degrees out.
Oldsmaniac is online now
Old July 21st, 2013, 05:08 PM
x?...180 out
oldcutlass is online now
Old July 29th, 2013, 03:08 PM
joepenoso's Avatar
Talking
Ran the motor 180* by hand and it fired up right away.
Thanks to everybody for you're interest and help
joepenoso
Old July 29th, 2013, 03:49 PM
Another satisfied customer, glad it's running.
Old July 29th, 2013, 05:44 PM
ziff396's Avatar
Same here. Been there before. Usually mine blew fire out of the carb. Once it did that, I knew that it was 180 out. Glad you found the problem.
ziff396 is offline
Old July 29th, 2013, 07:01 PM
And in the old days, the next thing that needs fixing if you were running a Holley was the power valve.
Old July 29th, 2013, 07:12 PM
72 Olds CS
RetroRanger's Avatar
so wait, when the marks are as shown in the below pic thats when #1 is on the comp stroke and I can put in the dist w the rotor pointing at #1 ?
Ive had my 350 apart and I would like to avoid any thru the carb backfires if I can
RetroRanger is offline
Old July 29th, 2013, 07:32 PM
My recollection (just tried to verify it, but can't find anything concrete) is that when the gears are in the position you posted ("6 and 12 o'clock"), the #1 cylinder is at TDC between exhaust and intake (ie: 180° out), which means that the "12 and 12 o'clock" position (green dot at 12:00, as it is in the picture, and yellow dot at 12:00, too) is the right position for aligning the distributor to the #1 cylinder.
Hint: It's the opposite of Chebby.
MDchanic is offline
Old July 29th, 2013, 08:14 PM
72 Olds CS
duh stupid digital clocks yes I blame the digital clocks for me not knowing where/what 6 and 12 is...
Oldsmaniac wrote that and I copied it but nothing was clicking
ok so I will rotate to the 12 12 position and put in the dist...thanks eric
Old July 29th, 2013, 08:18 PM
Remember, it's easy enough to confirm, because both valves are closed at TDC on the power stroke, which means you should have a tiny bit of rocker play or be able to spin the pushrods between your fingers.
MDchanic is offline
Old July 30th, 2013, 07:33 PM
ZATBAD 72
joades's Avatar
My manual shows the marks at 6 and 12. Is this not right?
http://www.flickr.com/photos/99610205@N07/9406340382/
joades is offline
Old July 30th, 2013, 07:41 PM
Yes, it is right.
They're both right.
The manual does not tell you to set it at 6:00 / 12:00 and then just stab the distributor - it tells you to confirm compression stroke by looking at the valve positions on #1.
The point of that picture in the manual is to make sure that you have the cam lined up right, which is easier with the dots right next to each other, not to have the engine set that way to put everything else together.
Remember, the point of the Engine section is not to tell you how to rebuild the entire engine, but rather to tell you how to repair individual parts that are broken - it says to put the distributor in the way it came out, and that if the engine has been turned, to check the valve positions and use that as a guide.
MDchanic is offline
Old July 30th, 2013, 09:07 PM
Or you can look at the rockers of #6 compared to #1.
Old July 31st, 2013, 07:11 AM
TripDeuces's Avatar
Eric you are correct. I timed my cam last week and when the timing set was dot to dot the cam is not on the base circle but 180* out. It's just a matter of turning it over so the dots are both at 12 o'clock. This puts the cam on it's base circle and the #1 piston at TDC on the compression stroke. The crank gear will rotate twice for every turn of the cam gear.
This is why timing the cam is stressed so much on this website and others. I was 3* retarded by installing mine 'straight up' and had to advance the cam by 4* to get it to 1* advanced.
TripDeuces is offline
Old July 31st, 2013, 07:37 AM
Professur's Avatar
Glad it's resolved. Just want to add, I had a similar problem on a '85 2.8 chebby that turned out to be a cracked magnet in the distributor. Nobody that looked at it caught that one.
Professur is offline
Old July 31st, 2013, 07:48 AM
Just curious - are you saying the timing set (or cam dowel pin) was machined 3 deg retarded?
Old July 31st, 2013, 07:50 AM
Oldsmaniac's Avatar
Originally Posted by MDchanic
Yes, it is right.
They're both right.
Very well explained Eric.
Old July 31st, 2013, 08:29 AM
Thank you, Joe.
MDchanic is offline
robgarner
August 9th, 2014 11:19 AM
Rocketowner
Site Suggestions
30
January 16th, 2014 04:47 PM
colemane
April 13th, 2013 01:19 PM
henryk8398
Ninety-Eight
27
December 13th, 2012 04:32 AM
Huron
July 14th, 2007 09:38 AM
Quick Reply: got the 455 together.nothing but an occasional backfire??
