How to tell if the right intake manifold
I know intake manifolds are swappable between 400/425/455's. I have a 66 425 2bbl and want to swap to a 4bbl. There is a non-EGR 455 4bbl manifold locally on Craigslist and I just want to make sure I am buying the right thing as I am not an expert like some of you out there. What do I look for to ensure this is indeed a 455 Olds manifold?
Thanks,
Rick
Thanks,
Rick
re: above...
...and what size carb should I be looking for? Mabe around 600 cfm??? I don't plan on cracking open the engine anytime soon as it runs pretty well. Just adding duals with Cherry Bombs I got off CL.
Thanks again,
Rick
Thanks again,
Rick
How to tell?...Easy, First make sure its a BB manifold....measure how wide your 2bbl is and compare it to the 4bbl. The 4bbl manifold will look the same as your 2bbl except for the 4bbl configuration. There are different choke options with the BB manifolds...one is for and air tube to carb choke and one has an area for a divorced choke.
Here's the ad:
http://minneapolis.craigslist.org/pts/831349382.html
The choke is part of the manifold. Do I need to stay away from this or would this be on OK way to go? How much (if at all) would it limit my carb search? Or do I even need to worry about having a choke? It won't be driven in cold weather. And I do not yet know if this is a "J" type manifold, which I guess would be the one to look for.
Thanks all,
Rick
Thanks all,
Rick
If it is a BB manifold that one is correct configuration for a 66 425 engine....the 4bbl used a divorced choke with quadrajet.....measure width to be sure it is a BB manifold or maybe numbers can be run on 442.com
Manifold
Rick, the manifold in the Craigslist ad has the divorced choke with it. That would put it 1969 or older. I don't know if the choke to carb rod is different lengths between 1966-69 but I believe you could get a quadrajet carb of the vintage of the intake and have a good setup. For that price, I'd buy it and then figure out what carb would work. Just the divorced choke coil is half the price he's asking for the manifold! John
shamusj
December 18th, 2014 09:28 AM
ddd777
March 22nd, 2013 09:05 AM
stocki26
Ninety-Eight
March 18th, 2013 10:13 AM
1966 442
November 17th, 2012 12:49 PM
