Identifying 455 by VIN Stamp
Old October 26th, 2013, 06:26 PM
Timmy1966_442's Avatar
Good evening,
I have a guess but I don't want to taint the answers on this one....
My 455 is stamped from what I can read its 30C110961. Casting number is 396021F ("Stick" F).
Thoughts?
Timmy1966_442 is offline
Old October 26th, 2013, 06:47 PM
allyolds68's Avatar
Originally Posted by Timmy1966_442
Good evening,
Thoughts?
1970 455 assembled in South Gate, CA
allyolds68 is offline
Old October 26th, 2013, 06:57 PM
same but different
don71's Avatar
yea, thats a 455 no doubt. What exactly do you want to know? It won't make much difference, it is what it is.
don71 is offline
Old October 26th, 2013, 08:27 PM
I was looking through the Tech section, didn't see a "C" code for a plant code. Just curious what the engine is out of.
Old October 26th, 2013, 08:35 PM
Interesting that it's red - I'd thought all '70 455s were blue.
MDchanic is offline
Old October 26th, 2013, 08:50 PM
The "E" heads are from 1970 as well, and the partial vin would have to match up to the vin on the car to be original. The vin will not tell you what it came out of if not original to the car.
1969w3155 is offline
Old October 26th, 2013, 10:35 PM
Justin
oldstata's Avatar
I think if you have the transmission vin matches you can decode its tag to see what class of car it was might help there if it was swapped as a whole unit
oldstata is offline
Old October 27th, 2013, 10:33 AM
That's because the Tech section is A-body centric. Only full size cars were built at South Gate during the 1970 model year. West coast A-bodies were built in Fremont, CA.
joe_padavano is offline
Old October 27th, 2013, 10:45 AM
allyolds68's Avatar
I found it by searching "assembly plant letters" on ClassicOlds, found this:
https://classicoldsmobile.com/forums...engine-id.html
and then realized that this list:
Originally Posted by svnt442
The letters are the assembly plant at which the car was assembled and the last 6 numbers are the order in which the car was assembled starting with 100001.
Here are the assembly plant codes.
B = Baltimore, MD
C = Southdate, CA
D = Doralville or Atlanta, GA
E = Linden, NJ
G = Framingham, MA
K = Kansas City, KS
L = Van Nuys, CA
M = Lansing, MI
R = Arlington, TX
W = Willow Run, MI
X = Fairfax or Kansas CIty, KS
Z = Fremont, CA
1 = St. Therese, Canada
2 = Oshawa, ON Canada
wasn't quite right because there's no such place as "Southdate, CA".
So I googled GM plants in CA and came up with "South Gate". BTW, South Gate was a BOP plant run by Pontiac
Old October 27th, 2013, 02:56 PM
Compression ?
Is there a way to tell if this motor was a low compression or high compression with pulling the heads off?
Also, Thank you all for the info. Nice to have a group with so much collective knowledge.
Old October 27th, 2013, 03:00 PM
Justin
oldstata's Avatar
70 should be a higher compression before the smog motors hit hard if it's original my 69 marine motor was rebuilt with lower compression guts but looking at the piston with the head of would tell you
oldstata is offline
Old October 27th, 2013, 03:24 PM
A '70 455 could be either 9:1, 10.25:1, or 10.5:1.
The 9:1 pistons had a half-moon notch at the front-facing side.
The 10.25:1 pistons had a V-shaped notch.
The 10.5:1 pistons were flat tops, with no dish.
You can look in through a spark plug hole with a bore scope to see them.
MDchanic is offline
Old October 27th, 2013, 05:20 PM
svnt442's Avatar
That was a copy and paste on my part and I never bothered to check for typos.....fixed.
svnt442 is offline
Old October 27th, 2013, 05:22 PM
svnt442's Avatar
I thought only the W31 got a 10.5:1 piston. I only remember seeing 2 pistons listed on the service manual for the 455 and 3 for the 350.
svnt442 is offline
Old October 27th, 2013, 05:39 PM
Maybe there wasn't a flat top in 1970. I thought there was.
MDchanic is offline
Old November 11th, 2013, 03:27 PM
Old post but I thought I'd update. I bought a $16 lighted Borescope camera ebay and identified the pistons on my 455. It is 9:1 compression. Not sure what that changes but now I know. Cool tool if anyone else is curious or needs to inspect cylinder walls or pistons.
Now should I be picking a different cam with the lower compression to keep it semi matched?
Old November 11th, 2013, 03:45 PM
Octania's Avatar
link to that borescope for us CB's?
Octania is offline
Old November 11th, 2013, 03:57 PM
You bet....
http://www.ebay.com/itm/151114740957...84.m1439.l2649
It was almost $19, not $16. Less than 20% over/under statement, so technically not a lie
Old November 11th, 2013, 05:52 PM
2blu442's Avatar
That is a cool looking gizmo! So does it actually record the photo, then you download with the USB port? Or do you have to attach it to a digital camera?
John
2blu442 is offline
Old November 11th, 2013, 07:12 PM
Neat toy. I could really use something like that from time to time, and I've been reluctant to spend $200 on something that will be obsolete in 5 minutes. $20, on the other hand...
MDchanic is offline
Old November 11th, 2013, 07:14 PM
Plugs into your computer like a USB. Software allows you to view, capture video, and take pictures. It was very easy to use. Here are a couple of the pics I took with it...
Old November 11th, 2013, 07:15 PM
I almost bought the one at Harbor Freight before I found this. One of those things that ends up in a drawer. But its cool to have about once a year.
Old November 12th, 2013, 11:22 AM
Justin
oldstata's Avatar
How big is the pic on the computer ? Is it the screen size or a tiny box
oldstata is offline
Old November 12th, 2013, 12:17 PM
Picture is about 1/4 the size of your screen. But I haven't played around with the settings much.
allyolds68
March 18th, 2022 04:37 PM
michaeljay0862
Wheels and Tires
August 21st, 2014 08:09 PM
Lars
February 1st, 2014 09:07 PM
Octania
November 1st, 2013 04:58 PM
dan1s
May 10th, 2008 10:31 AM
Quick Reply: Identifying 455 by VIN Stamp
