Mechanical fuel pump arm to timing chain clearance
Old March 12th, 2024, 04:38 PM
jskorz's Avatar
Restarting 455 build project ...mechanical fuel pump arm is rubbing against double-row timing chain even though the arm on the fuel pump does have a curve in it .... is there a mechanical fuel pump that has more of a curve that will clear the timing chain don't want to go with an electric pump.
Thx in advance
jskorz is offline
Old March 12th, 2024, 04:43 PM
BackInTheGame's Avatar
It should not touch the timing chain. If it does, then something is bent or out of alignment. The arm should ride on the Cam gear eccentric mounted to the face of the cam gear.
BackInTheGame is offline
Old March 12th, 2024, 04:44 PM
I’m curious, what pump are you using?
I remember having this exact problem with the cheap Holley mechanical pump on a 425. I solved it by using a rat tail file to slot the mounting holes just enough to clear the chain. Crude, but effective.
matt69olds is online now
Old March 12th, 2024, 07:59 PM
I have read the same clearance method when using a double roller timing set.
Fun71 is online now
NotDads442
June 2nd, 2018 07:35 PM
gunmetal71
May 6th, 2018 08:56 AM
330jetstar
July 18th, 2017 10:17 AM
HonestDave
August 31st, 2012 01:23 PM
eric72
March 1st, 2010 06:22 PM
Quick Reply: Mechanical fuel pump arm to timing chain clearance
