Mild 496 build
Old January 7th, 2015, 08:09 AM
madmax442's Avatar
Mild 496 build
Looking for help on cam selection for a mild build 496.
Heads will be C or Es upgraded to big valves. Prob mild port polish job and center divider built up. I want 10.25-10.5 compression with Cp or Mahle pistons. Performer rpm air gap or torker intake and demon 850 carb. Help on a hydraulic roller cam is what I'm after. I was thinking 550-575 lift maybe? Anyone got a combo close to this with power numbers?
madmax442 is offline
Old January 7th, 2015, 08:28 AM
cutlassefi's Avatar
If you can get the heads flowed that would be best. If they end up flowing better above the number you gave then it would beneficial to open the valve that far. If they don't then obviously not.
Finalize your combo and I'd be glad to help with a custom ground roller cam. Cam and lifters is $725.00 to your door.
Thanks.
cutlassefi is offline
Old January 7th, 2015, 10:01 AM
madmax442's Avatar
Yeah that sounds nice! I don't want to crazy on the heads because if I do then I might as well get edelbrocks. I have Cs I'm getting for $125 bucks and I'd like to get them upgraded to bigger valves with bronze guides and prob a good beehive spring able to handle up to .600 lift. A good valve and decent port and polish job. Hoping I don't get in over my head on these as far as cash flow. I have an unused set of battens as well as a set done by Brandywine but I think that's overboard and I'd have to have custom headers built. This engine is gonna be a stopgap build as my eventual setup is a full NASCAR style HP block batten headed F2 Procharger build.
Old January 7th, 2015, 12:51 PM
Stevec's Avatar
Wouldn't it be more cost effective to just get the edelbrocks?
Just sayin
Stevec is offline
Old January 7th, 2015, 01:53 PM
madmax442's Avatar
If my machine shop can do it all for less than 1k for me then I'll have the Cs worked. If it's over 1K I'll prob just get Edelbrocks.
Old January 7th, 2015, 03:53 PM
Stevec's Avatar
Gotcha!
Stevec is offline
Old January 7th, 2015, 03:59 PM
Rallye469's Avatar
I know this is a question everyone will ask...
but what are your plans for the car? Do you have a # you want to run?
Remember spending $800 bucks on C's just means that your eventual purchase of Edelbrocks or better just cost you $800 more.
Rallye469 is offline
Old January 7th, 2015, 04:27 PM
madmax442's Avatar
This engine is going to be an in between motor. I'm putting this one together so I can get the car on the road. It currently has a 502 BBC that I want gone! The car is currently drag only but it's going into the body shop next month for paint and I want it back on the street and want true olds power till I buil my serious street strip NASCAR engine!
Old January 7th, 2015, 05:30 PM
cutlassefi's Avatar
Originally Posted by Stevec
Wouldn't it be more cost effective to just get the Edelbrocks?
X2. Just get the Edelbrocks, or even Procomps. Don't waste your money on the stock irons.
Old January 7th, 2015, 05:34 PM
madmax442's Avatar
Ugh I knew everyone would say that! Lol
Old January 7th, 2015, 05:51 PM
madmax442's Avatar
Hey Cutlassefi do you sell edelbrock heads?
Old January 8th, 2015, 01:29 AM
EightballZ's Avatar
yes he does. purchased a really nice set with bigger valves...good guy!!
EightballZ is offline
Old January 8th, 2015, 03:27 AM
madmax442's Avatar
I'll have to ask him about it.
jims2000lt
June 24th, 2013 07:47 AM
Bad Mr B
October 4th, 2012 03:30 PM
wills30
July 29th, 2012 08:16 AM
67townsedan
September 29th, 2010 06:30 PM
1964F85
February 12th, 2010 07:14 PM
Quick Reply: Mild 496 build
