Oil - Intake Problem?
Old May 20th, 2007, 07:52 PM
toneypenna's Avatar
Big Block 455, 60 Over. Have Had A Problem With Oil Collecting In The Edelbrock Performer Intake Runners Which Causes Engine To Smoke. Tried Different Gaskets,( I Should Buy Stock In Fel Pro) Adhesives Etc. Also Tried A Cast Iron Manifold.
Started Out With C Heads That Were Ported, Changed To A Set Of G Heads Not Ported, Same Problem. I HAVE RULED OUT THE PCV.
Need Help ! Anybody Out There Ever Have A Similar Problem Or Have Any Ideas.
toneypenna is offline
Old May 20th, 2007, 09:00 PM
shaks 442 clone's Avatar
i think i read its best to use the fel pro gasket when using the performer intake
i believe i read it on summitracing.com in the description of the intake
shaks 442 clone is offline
Old May 21st, 2007, 05:26 AM
toneypenna's Avatar
I Used Mr. Gasket # 404 (recomended By Edelbrock) Numerous Times With Different Adhesives. Also Found On The Mr. Gasket Web Site Under Installation Tips To Use The Valley Pan Gasket Together With The # 404 Gaskets. Problem Still Persists
Old May 21st, 2007, 05:54 AM
Past Administrator
Oldsguy's Avatar
Worn valve guides? I know you said two differrent sets of heads but that is what first came to mind.
Oldsguy is offline
Old May 21st, 2007, 07:06 AM
Oldsmaniac's Avatar
I would look at intake for possible crack and if there are any threaded holes in the manifold for plugs make sure they are there on floor under carb and underside. Thick paper gasket from MR Gasket should seal......
Oldsmaniac is offline
Old May 21st, 2007, 07:45 PM
toneypenna's Avatar
Both sets of heads are rebuilt, new guides etc.
Thanks Jim P
svnt442
July 17th, 2011 04:43 PM
elwood565
July 1st, 2009 12:59 PM
nitinnelapudi
June 11th, 2008 05:39 AM
cutlassdriver61
January 5th, 2008 04:04 PM
Quick Reply: Oil - Intake Problem?
