Oldsmobile 403 header gaskets
Old March 27th, 2009, 06:59 PM
65az's Avatar
Anyone recommend a place to purchase these? I am not having much luck...
65az is offline
Old March 27th, 2009, 07:08 PM
Except for the roller cam 307s, all Olds motors use the same gaskets. Any Olds 350 or 455 gaskets work find. I'd recommend copper.
joe_padavano is offline
Old March 27th, 2009, 07:18 PM
65az's Avatar
That is what I thought.. but the last two autoparts stores I talked to stated that the 403 was different, and that they are not finding any availability...
65az is offline
Old March 28th, 2009, 02:09 AM
Yellowstatue's Avatar
Smile Copper?
Now that you have mentioned it, what is the advantage of copper gaskets??aren't they thinner??
Yellowstatue is offline
Old March 28th, 2009, 06:05 AM
The good copper gaskets have an embossed bead around each port. The bead compresses to form the seal and make up for unevenness.
Old March 28th, 2009, 06:06 AM
So tell them it's a 350.
Old March 28th, 2009, 12:25 PM
Buy the Summit or Mr. Gasket set:
http://store.summitracing.com/egnsea...view=sku&RC=10
Olds64 is offline
Old March 28th, 2009, 12:45 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Then he'll end up with chevy gaskets
J-(Chicago) is offline
Old March 28th, 2009, 09:21 PM
Smile Metalica
Thanks for the info..my other thought was...is there an advantage for the metal to metal heat transfer down the hedders
iam2fast4u86
April 15th, 2016 08:20 AM
76olds
December 16th, 2013 02:25 PM
tdubis
October 21st, 2011 11:45 AM
brewcity
April 5th, 2011 09:36 PM
geckonz08
July 15th, 2009 11:01 AM
Quick Reply: Oldsmobile 403 header gaskets
