Radiator dimensions and sizing quandries
Ok, I have a 1970 Cutlass S that originally had a 350/4BBL/TH350 that I am putting in a 455. However, it seems the radiator that I have that was included with the car (not installed) is oversized for the hardware. It doesn't quite fit and seems to be about an inch too tall.
What should the actual dimensions be so I can buy a new radiator that will fit? Seems like there is a 17" tall version and an 18" version. Were 350 powered cars 17" and 455 powered cars 18"? Also, seems like the thickness is different too. The one I have is def too thick to actually fit.
And then, sources of a new one that will fit AND keep it cool?
Thanks all,
Thanks all,
From what I know, the radiators all had the same width and height. The difference was the thickness: 2 row, 3 row, or 4 row. The 2 and 3 used the same end tanks, so the same top plate and saddle width. The 4 row had thicker end tanks and used a different top plate with wider saddles, along with wider bottom saddle.
You could bolt your top plate in and measure the height to see what would fit.
The availability of radiators online show two different heights, one 17" and one 18" tall. Also, the radiator I have is 3" across where it meets the top rubber isolaters, but the top plate seems to want something that is not 3", but something less like 2.5-2.75". Same for the bottom isolaters. It's the same thing down there. The radiator is too wide/thick for the rubber mounts and they look like they are original.
I'll go out there right now and put the top plate and shroud in and make some measurements.
Taking rough measurements for you as the car is still together. 1970 W-30 measurements are 19" high 29" wide 3" thick. These are the rough measurements of the core only ( not counting the tanks ).
One thing you will want to do is convert to the 4 core saddles for a 455 car. I did, got them from Thornton Muscle Cars and installed this radiator, fits like a glove and cooled my 9+ to 1 Olds 403 with ease. Unfortunately Thornton is currently out of stock on the 4 core brackets and rubber mounts.
https://www.ebay.ca/itm/351157989603...mis&media=COPY
And I will likely need a 4 row top plate. Time to text the usual suspects on what they have in their stash...
Exactly what did as well, drill out the rivets and put in the 4 core top mounts. Hopefully someone has the 4 core top mount and cushions available. I bent the bottom saddles to fit the bottom rubber pieces.
Thanks guys! I have also ordered a cheap replacement radiator and will use that to flesh out any issues with what I have now before I do the mods to accommodate the big radiator I ordered.
I went ahead and ordered these since Thornton's doesn't have them right now.
https://www.inlinetube.com/products/inl11050
Texas442
December 8th, 2010 08:16 AM
