Radiator hose '66 toronado
Old February 18th, 2022, 06:38 AM
'66toro's Avatar
Adding to my issues with replacing my radiator on my '66 Toronado is that I'm finding that the "lower" hose neck on my original radiator is 1 1/2" but new hoses are 1 3/4". I have had 2 new hoses now, the first one, a corrugated Dayco, was 1 3/4" and the 2nd hose, a continental elite molded hose, was also 1 3/4". The old one I took off was a corrugated hose and was also 1 3/4" and the neck had a small 3" section of 1 1/2" hose on to accommodate (take up the difference), of the bigger 1 3/4" old hose. My question now is, why are the new hoses larger at the neck end or is it that my original radiator, has been repaired at some time and a smaller lower neck added for some unknown reason?
'66toro is offline
Old February 18th, 2022, 06:49 AM
Manufacturers of replacement parts want to minimize costs so they can maximize profits. There is very little profit in parts for cars that are over half a century old, especially ones that are not popular to restore, so they try to make one P/N accommodate as many different applications as possible. In this case, a readily available bushing solves the diameter problem.
joe_padavano is online now
Old February 18th, 2022, 07:04 AM
'66toro's Avatar
Ok, great, so where can I get one of these bushings?,,,
'66toro is offline
Old February 18th, 2022, 07:09 AM
Type radiator hose bushing into Google.
Old February 18th, 2022, 01:15 PM
Oldsdruid
rocketraider's Avatar
Toronado lower hose diameters are different at radiator end between 66-69 and 70-77. Bushing is your best bet. It's a workaround and another leak point, but you do what you must.
You might also want to check with www.fusick.com and see if they can furnish a correct reproduction hose instead of fooling with that one-size-fits-none flex hose mess.
rocketraider is online now
Old February 18th, 2022, 01:27 PM
'66toro's Avatar
Yes, the continental molded hose i got is of good quality but needs the bushing/reducer. Gates makes them but none of my local parts places, auto zone, advance, auto, NAPA, O'Reilly, etc. has it in stock, not a common asked-for item I would guess. but thanks to the dying mom and pop parts stores that are still in business, I found one that had it on the shelf and for a lesser price than the competitors online and I don't have to wait to get it shipped,,,
'66toro is offline
Loaded68W34's Avatar
The hoses (top and bottom) on my 68 are from fusick. No fitment issues.
Loaded68W34 is offline
Old February 18th, 2022, 01:33 PM
'66toro's Avatar
The top hose on my '66 Toronado is fine, both the radiator and the intake H2O fitting are the same at 1 1/2", I found it easy to buy that hose off the shelf at most parts stores,,,
'66toro is offline
Old February 18th, 2022, 04:29 PM
442Harv's Avatar
I have a 70 W30 car.Someone changed the water pump, and put on a 71 pump, which is the smaller hose, maybe someone put a different year pump on?
442Harv is offline
Tom442
June 12th, 2017 05:51 PM
chip-powell
April 20th, 2017 07:24 PM
CutLS
Non-Olds Engines
March 1st, 2016 07:14 PM
OldsManNJ
March 23rd, 2011 08:47 AM
njot33
February 25th, 2008 08:18 AM
Quick Reply: Radiator hose '66 toronado
