Roller Lifters with a flat tappet cam?
Old March 8th, 2013, 05:02 PM
RROLDSX's Avatar
Just wondering with the low zinc oils being a problem with flat lifters, can a guy use rollers lifters until he gets around to changing the cam out?
If so, what would need to happen with the push rods?
How does everyone get around using expensive specialty oils?
RROLDSX is offline
Old March 8th, 2013, 05:08 PM
jensenracing77's Avatar
NO! The cam is made for flat lifters. The cam is made with a slight taper for the flat tappets and also the lobe profile is an entire differant animal. You will just have to buy good oil or a quality additive. I don't like additives other than breakin so i started buying Brad Penn.
jensenracing77 is offline
Old March 8th, 2013, 05:36 PM
RROLDSX's Avatar
Yes of course!
I forgot about the taper (DOOOH!) Just a little rusty.
Thanks for the reply.
RROLDSX is offline
Old March 8th, 2013, 05:50 PM
ah64pilot's Avatar
Just use Valvoline VR1 Racing oil and call it a day. It's not that much more than regular oil and it's good to go for any flat tappet cam. It has a high ZDDP content...I use it in all of my cars, even the silver car that has a mech. flat tappet cam with a fairly aggressive cam profile.
ah64pilot is offline
72cuttys
May 31st, 2019 03:52 PM
van Dyck
January 27th, 2013 12:58 PM
jensenracing77
April 25th, 2012 05:09 PM
VinMichael
April 4th, 2012 07:10 PM
Redog
August 14th, 2008 06:56 PM
Quick Reply: Roller Lifters with a flat tappet cam?
