Sanderson shorty headers
Old February 6th, 2014, 12:05 PM
Beer Connoisseur
70cutty's Avatar
Is there any shorty headers for 455?
Looking for headers that will not drag on the floor that I don't have to pay a small fortune for.
70cutty is offline
Old February 6th, 2014, 03:23 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
No, other than center dumps, which won't work. The SBO Sanderson are tiny 1 5/8" primary tube. The Hedman for the SBO might work, you would have to try them.
olds 307 and 403 is online now
Old February 6th, 2014, 08:00 PM
edzolz's Avatar
I have a set of the Hedman shorties that I am going to run on my street rod. They look like they would work on any A or G body with any engine combo.
edzolz is online now
Old February 6th, 2014, 08:09 PM
joepenoso's Avatar
Why not the W & Z cast iron headers?
joepenoso
joepenoso is offline
Old February 7th, 2014, 07:45 AM
Shorty headers and W/Z manifolds have no real performance benefits. They just fit a little better. Long tubes are for performance.
oldcutlass is online now
Old February 7th, 2014, 08:08 AM
citcapp's Avatar
correction, the 455 Sanderson headers are 1-7/8" dia. I am using them on my 48 Olds because of clearance issues
Sanderson O455 Header Set for Oldsmobile 455
View detailed images (2)
The O455 header fits Oldsmobile 455 engines in a variety of street rods and customs which do not have a crossmember under the center of the engine. The compact design of the O455 clears all types of steering and motor mount setups.
Includes all hardware necessary for installation.
SPECIFICATIONS:
Engine : Oldsmobile 455 V8
Primary Tube Diameter : 1-7/8"
Collector Diameter : 3"
Weight : 15 LBS / 6.80 KGS
citcapp is offline
Old February 7th, 2014, 08:30 AM
Beer Connoisseur
70cutty's Avatar
I don't think I can run those in my Cutlass. I guess my only option is American Racing or raise the car back up. I think all the other headers are hanging way too low. My hooker headers on my 350 are only couple of inches of the ground. My car is lowered I had to put 1/2" spacer in my spring cause I couldn't get out of my driveway without scraping. I don't want to that with 455.
70cutty is offline
Old February 8th, 2014, 01:09 PM
Delmont 88 PA's Avatar
I used Sanderson shorties on my '67 Delmont 88 with a 455. It took a lot of work and, if long tube headers would have fit, I definitely would have used them.
Delmont 88 PA is offline
Old February 15th, 2014, 12:15 AM
64Rocket's Avatar
These are the ones I used on my car,
http://www.summitracing.com/parts/HED-58160/
Gene
64Rocket is offline
Old February 15th, 2014, 03:53 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I clicked on the Summit link and watched the video they have. It is very informative about the difference between full length and shorty headers. The Hedman shorties do not fit a 455.
redoldsman is online now
Old February 15th, 2014, 07:48 AM
American Racing headers are the way to go. If I ever swap headers, they would be my only choice worth buying.
Old February 15th, 2014, 07:56 AM
Beer Connoisseur
70cutty's Avatar
I ended up buying Doug's ceramic coated. It seems better quality than hooker. Made out of thicker steel. I will post how they fit in few weeks when they arrive with the engine. $729 free shipping.
70cutty is offline
Old December 8th, 2016, 10:05 AM
Rodney
cdrod's Avatar
header fit
I know this thread is nearly 3 years old, but I would love to see how well these headers fit your car. Here's hoping the OP will post some pics.
cdrod is offline
Old December 8th, 2016, 10:14 AM
wr1970's Avatar
You are slow. He bought American Racing at some point and was unhappy with them.Maybe he will post back.
wr1970 is offline
Old December 8th, 2016, 10:47 AM
Beer Connoisseur
70cutty's Avatar
I ended up returning Doug's headers, driver side fit ok but passenger wouldn't even bolt up. After they were returned I spoke with a tech from Doug's, he said they it was their mistake and headers were not built right from the factory. he also mentioned I wasn't the only one with the issue.
So I went with ARH and after some modifications they are in the car. On ARH I had to tweak the driver side.
I started thinking maybe it's my car, but my old Hooker headers ($50 at the swap meet) fit with no issues so it couldn't be the car.
If I had to do it all over again, I would go with DMR headers.
70cutty is offline
Kyle's 77 Cutlass
April 13th, 2014 11:30 AM
Delmont 88 PA
February 3rd, 2013 06:11 AM
olds 307 and 403
January 24th, 2012 03:28 PM
adis
October 22nd, 2011 07:40 PM
|-K|=K
July 28th, 2011 03:02 PM
Quick Reply: Sanderson shorty headers
