Setting piston ring side clearance
Old May 13th, 2011, 07:47 PM
OLDSmobility's Avatar
Getting started on the assembly of my new 455. Got my piston ring endgaps set, and went to check the ring to ring land setting. The Mondello Tech Reference manual and the factory specs call for .002"-.004" clearance there. I also have Bill Trovato's book, but this particular spec isn't listed anywhere. Anyway, my SpeedPro rings just fit in the grooves of the L2323 pistons with very little clearance. In fact, I can't get a .0015" feeler gauge between them (the smallest I have). Do I need to surface all of them until I get the recommended .002"-.003" clearance?
OLDSmobility is offline
simonb.
May 2nd, 2014 08:08 PM
dallasite21
August 10th, 2012 08:02 PM
edzolz
May 25th, 2012 04:16 AM
MrLightning
June 5th, 2011 06:39 PM
nonhog
September 17th, 2010 05:34 PM
Quick Reply: Setting piston ring side clearance
