Speed master heads...
I have looked around and just wondering if these heads will accept stock valve train? I’m looking for weight savings over the cast iron heads I have now. I don’t have the clearance to use roller rockers unfortunately... what is everyone’s thoughts on these heads out of the box?
Overall a pretty decent piece.
The problem might be how many sets of these heads already exist and sit in the US warehouses. Much of China is shutdown and under quarantine, and it doesn't look like this will change anytime soon. The businesses and factories in China are many times very small and may not survive this shutdown of production and trade.
OP, I would get the heads already gone through and set up from either Mark aka CutlassEFI, or Bernard Mondello racing Enterprise.
I'm pretty sure there is quite a bit of supply sitting around in warehouses. I mean there are everywhere on the net and few weeks of quarantine will not affect Oldsmobile market, hell few years would not affect Oldsmobile market for aftermarket heads.
https://www.forbes.com/sites/steveba...e-coronavirus/
Attention to detail. Valve guides may not be sized properly, probably have casting flash in the runners, probably at least need to be cleaned, the valve seat will have been, ah, "efficiently" cut, deck, intake and exhaust surfaces may not be anywhere near flat.
The casting flash can break off and break stuff.
Valve guides too tight can seize valves and break stuff. Valve guides too loose can leak oil.
Frankly, Edelbrock heads need the same QA, but usually very few fixes are required.
They're made-in-China by (or for) a company that ran it's original name into the ground due to ****-poor quality. So they change their Company name, pretend to be better, and sell the same compromised stuff.
Speedmaster was actually their original name.
Best out of the box cyl head for an Olds is an Edelbrock.
Typically only the guides need touching up but I’ve taken apart a few that we’re just fine. Stock valve job is more for durability and longevity, but can be improved as well if desired.
But I’ve sold and/or used dozens of sets of bare Procomp/Speedmaster heads, no issues.
