Torque sequence and specs
Old June 24th, 2013, 12:29 PM
ctreutel's Avatar
Hi Guys;
I'm about to reassemble my 1976 455. I have a 1969 chassis service manual with all the specs...but I want to be sure the torque specs and sequence for the heads, rods, intake, etc...is all the same from 1968-1976 on the 455 engine.
ctreutel is offline
Old June 24th, 2013, 01:51 PM
cutlassefi's Avatar
Stock bolts on everything? If so then follow the service manual.
cutlassefi is offline
Old June 24th, 2013, 02:01 PM
ctreutel's Avatar
Yes...stock bolts for the most part. If I do need to get different bolts [may want to get stainless bolts for the intake], what do I need to watch out for?
ctreutel is offline
Old June 24th, 2013, 03:37 PM
Octania's Avatar
Yes, the torque values are the same for '69 and '75.
Intake bolts are not torqued heavily so SS should work there.
Watch out for?
Crappy Chinese fasteners, grade 2 hardware...
Stick with factory fasteners for the right look or deviate up, like Grade 8's where not necessary- intake, water pump, t'stat housing, bellhouse to block, etc.
Socket head cap screws are very strong also, but generally plain black finish and not that good at rust resistance.
Octania is offline
Old June 24th, 2013, 04:33 PM
Socket head cap screws come in stainless also.
Here's the torque specs:
http://www.442.com/tech/torque.html
Head:
Intake:
oldcutlass is online now
Old June 24th, 2013, 05:48 PM
Octania's Avatar
Watch out for?
Octania is offline
Old June 26th, 2013, 04:01 AM
ctreutel's Avatar
Thanks much!
ctreutel is offline
wcourt3010
April 13th, 2015 12:10 PM
Don Roberto
April 11th, 2015 09:48 PM
Franks425442
March 9th, 2011 12:08 PM
nukesec1
October 6th, 2009 12:42 PM
mcutlass1969
Drivetrain/Differentials
August 18th, 2008 09:59 PM
Quick Reply: Torque sequence and specs
