Intake torque sequence
Old October 5th, 2009, 12:43 PM
nukesec1's Avatar
I searched for this on the form and can't find anything. I need to buy a manual! I'm looking for the torque sequence and the ft/lbs torque value for the iron 1973 Olds 350 4bbl intake. Got it all prettied up with fresh gold paint and ready to assemble! Won't be until this weekend though. Gotta work all week. Dangit.
nukesec1 is offline
Old October 5th, 2009, 01:49 PM
svnt442's Avatar
let me see if I can help......
Here ya go.
svnt442 is offline
Old October 5th, 2009, 02:07 PM
citcapp's Avatar
Here are the complete torque specifications
http://www.442.com/tech/torque.html
citcapp is offline
Old October 5th, 2009, 09:11 PM
OMG!! How can you read that?? Yellow print on an orange background? My eyes just about bugged on me.
I copied just the engine specs and redid them in B/W. Much easier to read....
Torque Specs 330, 350, 400, 425 & 455 Engines
** = Clean and dip entire bolt in engine oil before tightening
*** = 455, 350 and post '67 400
APPLICATION FT.LBS.
FUEL PUMP
Fuel pump to block bolt and nut............................25
Fuel pump eccentric to camshaft............................65
EXHAUST SYSTEM...........................................1 5-20
ENGINE
Crankshaft bearing cap bolts (400 & 425 engines)..........120
Crankshaft bearing cap bolts # 1,2,3,4 (330 engine)........80
Crankshaft bearing cap #5 (330 engine)....................120
Cylinder head to block.....................................80 **
Connecting rod nuts........................................42
Oil pump to bearing cap bolts..............................35
Oil pump cover to pump bolts................................8
Rocker arm studs to head...................................35
Rocker Arm Pivot Bolt to Head..............................25 ***
Rocker arm nuts to studs...................................25
Valve cover bolts...........................................7
Oil pan bolts (5/16")......................................15
Oil Pan Bolts (5/16).......................................12 ***
Oil pan bolts (1/4")........................................8
Oil pan drain plug.........................................50
Oil Pan Drain Plug.........................................30 ***
Crankshaft balancer or hub to crankshaft bolt..............50
Crankshaft Balancer or hub to crankshaft bolt.............120 ***
Oil filter element to base.................................20
Oil filter assembly to cylinder block bolts................35
Front cover to cylinder block bolts (3/8").................35
Front cover to cylinder block bolts (5/16")................25
Fan driven pulley to hub bolts.............................20
Fan driving pulley to hub or balancer bolts................20
Water pump to front cover bolts............................13
Water outlet to manifold bolts.............................20
Intake manifold to cylinder head bolts.....................35 **
Intake manifold baffle to cylinder block bolts..............8
Exhaust manifold to cylinder head bolts....................25
Carburetor to intake manifold bolts and nuts...............15
Tube and plate to intake manifold bolts....................15
Air cleaner to carburetor stud..............................5
Motor mount to cylinder block bolts........................50
Starter to cylinder block bolts............................35
Starter brace to cylinder block bolt.......................25
Starter brace to starter bolt..............................15
Distributor clamp to cylinder block bolt...................14
Distributor Clamp to Cylinder Block Bolt...................17 ***
Spark plugs............................................. ..35
Coil to intake manifold bolt...............................15
Allan R is offline
Old October 6th, 2009, 07:17 AM
nukesec1's Avatar
SHABAM! Thanks guys that's what I needed! Now if the weather will cooperate with me this weekend so I can get it all back together before I lock it up in storage I'll be happy.
nukesec1 is offline
Old October 6th, 2009, 12:42 PM
svnt442's Avatar
The entire site is like that. I guess he thought it looked cool or something.
svnt442 is offline
Don Roberto
April 11th, 2015 09:48 PM
ctreutel
June 26th, 2013 04:01 AM
Franks425442
March 9th, 2011 12:08 PM
mmurphy77
May 12th, 2010 05:30 PM
stevengerard
September 22nd, 2009 09:07 PM
Quick Reply: Intake torque sequence
