Upcoming 455 Build Questions
Old April 3rd, 2012, 07:43 PM
69350rocket's Avatar
Going to look at a 455 this weekend. Unfortunately it has J heads, but I'll ditch those for a set of C heads. My car is going to be pretty much a weekend warrior, and will be drag raced often. I am going to build the engine in stages, doing bottom end before I put it in, and then top end sometime later down the road. I want to get the car into the 12's for now, and someday deep into the 11's. I want to run pretty high compression, like 12-12.5:1, which will help power out a lot. I'm gonna run a water/methanol injection setup so I can keep it on 93 octane. I'll be using ARP rod bolts and main studs. Maybe billet main caps? I'm going to be running a hydroboost brake setup, so cam selection wont really be limited by vacuum production. Ill probably have Cutlassefi custom grind me one, possibly hydraulic roller? My questions are, is there a piston that will get me that much compression or will I need a custom set? And since this is a later 455, it wont have the nodular crank will it?
69350rocket is offline
Old April 4th, 2012, 05:32 AM
cutlassefi's Avatar
Thank you.
It might have an N crank, you'll just have to open it up and see.
If you're going high compression and using billet caps, it doesn't make sense to use the stock rods. Throw them away and buy some Eagles.
SRP and others make a true flat top piston for the 455, should get you in the low to mid 11's for compression at least. From there you'll need to mill the heads further.
Speaking of heads, go aftermarket. Their better, you can mill them more and they won't run you much more than a set of of totally reworked stockers. That SRP piston, Edelbrock or similar heads milled to 70cc with a 0 deck gets you 12.25:1.
But I think you could run 11.0:1 or better on just plain pump and with the right setup still get into the low 12's/high 11's without too much trouble. either.
Jmo
cutlassefi is offline
Old April 4th, 2012, 09:17 AM
Alright, ya I guess I may as well upgrade the rods. Who makes a quality set of billet mains that dont cost a fortune? And would a hydraulic roller be worth the extra money for this build?
Old April 4th, 2012, 11:13 AM
cutlassefi's Avatar
Try Rocket Racing for the mains but strapping and studding them is usually more than adequate for most applications.
Cam will depend on cylinder heads.
Old April 4th, 2012, 07:16 PM
Okay so maybe I wont need the billet mains then. Heads will probably be heavily ported C heads.
Old April 5th, 2012, 07:41 AM
Run to Rund's Avatar
For weekend type use and racing, I suggest race gas instead of water/methanol. Without power adders, you don't need extra main support, or maybe just studs if you go low 11s. To do that, you will be going about 118 mph in the quarter (a good estimate of power produced) and you can do that with stock main caps and re-used bolts. You can also do that with B or C heads and a stock intake if the car is well sorted out.
Run to Rund is offline
Old April 5th, 2012, 04:38 PM
Well, the car will be driven quite a bit on the weekends, so race gas is kinda out of the question. There is no way I could afford to drive it much with race gas.
wizarddrummer
October 1st, 2011 11:29 AM
66ninetyeightls
September 6th, 2011 07:56 PM
cutlass xombie
August 12th, 2011 06:02 PM
malibu406
September 13th, 2010 10:02 AM
1964F85
July 29th, 2010 06:37 AM
Quick Reply: Upcoming 455 Build Questions
