Valley Pan
Old July 29th, 2007, 04:12 PM
mcutlass1969's Avatar
Valley Pan
Ok I am back to this 455 Valley Pan again. In using it do we use the edges as gasketso? If so just RTV above and below? If not which side do we add the intake gaskets? On the heads side or intake side?
mcutlass1969 is offline
Old July 30th, 2007, 04:01 AM
Jim's rare 80
Jim's rare 80's Avatar
If you are using the valley pan, it is the gasket. Use sealant around both sides of all openings. Don't use another gasket with the valley pan. It's one, or the other. Hope this helps. Jim.
Jim's rare 80 is offline
Old August 5th, 2007, 01:14 AM
caveman442's Avatar
i use coppercote spray on those both sides
caveman442 is offline
Old September 24th, 2007, 07:51 PM
71 delta88guy's Avatar
or better yet. screw the valley pan. Vacuum leaking,overpriced piece of junk it is. Go with the 4 piece gasket from mr. gasket. Nice thick port side,chuck the ends and use ultra black,ultra blue,or even better, use ford rtv designed for oil pans on the 7.3 diesel. It'll take 3 guys to get it off again if you ever have to and will never leak oil.
71 delta88guy is offline
Old September 25th, 2007, 05:23 AM
Past Administrator
Oldsguy's Avatar
IF you do use the valley pan, practice inserting it dry, make sure you have it correct side to the front. You should follow the directions about not using silicone on the front and rear seals except for the corners, if you don't and add silicone to the bottom and top of the end gaskets they might slip off. Some people cut out the center section completely, I haven't in the past but did try it this time but haven't had the engine running yet to see if it leaks or not. I think next time I will follow 71 delta88guy's recommendation though.
Oldsguy is offline
Old September 25th, 2007, 04:11 PM
JB Weld.
Olds64 is online now
Old October 24th, 2007, 06:11 PM
W30post's Avatar
Just went through the intake gasket again on my W-30. This is a stock motor with factory aluminum intake. The advice I was given many times is cut the turkey tray so it fits in the motor and doesn't get in the way of the Mr. Gaskets intake seals. That keeps the hot oil off the bottom of the intake.
Also make sure you retorque the Mr. Gasket seals. I didn't on the first try and it caused an exhaust leak at the intake to head surface. I was told to retorque after about 6 to 10 heat cycles of the motor until they completely stop compressing.
I didn't use the end seals, just RTV. One last thing about either of the Mr. Gasket #404 or the Ultraseals, they do not have the exhaust port opened under the carb. You have to do that one yourself. I used the factory gasket for a template then cut away what wasn't needed. If you don't do this the car can be very anemic when cold if tuning is on the rich side.
James
W30post is offline
Old October 24th, 2007, 06:37 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
James
I was just going to mention that.
I use the turkey tray and an assload of Blue Rtv personally.
I have 60000 miles on the intake now and still no issues. Thank god.
J-(Chicago) is offline
Old October 24th, 2007, 07:40 PM
The regular blue rtv should not be sold anymore. It sucks! The addition of the ultra rtv's is so much better than the old and tired and sucky plain blue rtv it should be retired. Sick to death of prying it from oil pump srtainers by people who used it as described and had it break off and clog the oil pickup.Ultra grey is the best of the ultra's. Manufacturer rtv's are even better. Mitsubishi,nissan and ford/international have rtv's so much better than a gasket it's just sick. Try them.
Old October 24th, 2007, 07:49 PM
Delta 444
For the Delta
haha.
File Type: gif
Old October 24th, 2007, 08:15 PM
The_Jeremiah's Avatar
woo
wait im not quite understanding this. did you say cut the sides off where the it normally joins the manifold and head, and leave the main part of the valley pan ? can you do that ? where do i get this 4 piece mr gasket set you guys mentioned ?
The_Jeremiah is offline
Old October 24th, 2007, 08:41 PM
soxfan's Avatar
You can get the #404 gaskets from just about any auto parts store. Most sell Mr. Gasket items. If you didn't want to go to an auto parts store you can call or buy the gaskets online from suppliers like Summit.
soxfan is offline
Old October 25th, 2007, 05:00 AM
Past Administrator
Oldsguy's Avatar
He was saying TRIM the valley pan part so it doesn't bind or scrape the insides of the block "so it fits the motor". At least, that is what I understand. It makes sense to me. Someone mentioned that the manufacturers silicone sealant is best. My buddy the 30 year mechanic agrees. Along his way of advancement he worked at a Toyota dealership (I think that is the one) and he still uses their stuff. I don't know if us normal human beings can get that or not but would be worth a try. I have never used the blue stuff, always the black stuff. It works for me and I have never found an oil pickup clogged, yet....
Oldsguy is offline
ddx77
June 14th, 2010 07:37 AM
Wasted
May 24th, 2010 06:55 AM
rtpassini
April 25th, 2010 06:41 PM
Flye
May 12th, 2009 05:30 PM
mcutlass1969
July 12th, 2007 04:55 AM
Quick Reply: Valley Pan
